ᐅ Ikea Besta – What to do if assembly gets stuck halfway through?
Created on: 30 Nov 2024 19:42
EsrarenHello everyone,
I am currently in the middle of assembling my Ikea Besta cabinet and have encountered a problem that I can’t resolve. The instructions are generally clear, but I’m unsure how to securely connect the side panels to the back panel. Specifically, in step 7, I am asked to insert and screw in the back panel, but the pre-drilled holes do not align perfectly. This makes it difficult to insert the screws straight, and I’m worried about damaging the material or not being able to set the cabinet up level afterward.
My questions are:
- Is it normal for the holes in Ikea Besta cabinets to sometimes not match perfectly, or could this indicate a manufacturing defect?
- Are there any tips or techniques to install the back panel as securely as possible without damaging the wood?
- Should I force the screws in anyway, or is it better to wait and maybe contact Ikea customer service first?
I only have standard tools available (screwdriver, cordless drill with torque control) and have some experience with furniture assembly, but this issue has me stuck. I would really appreciate any help or shared experiences!
My questions are:
Great that you describe the situation so precisely! 😊 This makes it much easier for us to help you! I remember when I last assembled the Besta – yes, the holes can sometimes be slightly misaligned, which is often not a mistake but due to Ikea’s manufacturing tolerances.
My advice: Never force the screws all the way in by brute force! Instead:
- Check if you can slightly shift the back panel so the holes align better.
- Use a cordless drill with low torque to avoid splitting the material.
- If the back panel is made of thin material, it might help to pre-drill lightly with a thin drill bit.
I was worried at first too, but with a bit of patience everything held perfectly. Keep going, you can do it!
I can well understand how frustrating this can be, especially when you put in a lot of effort and then a sticking point stops the assembly. It once took me days to dare tackle a difficult spot when assembling a Besta.
What helped me was taking a step back, carefully reviewing the instructions again, and checking each individual part. Sometimes a board is slightly warped or the back panel doesn’t fit properly along the edge, so the holes don’t align.
Considering contacting Ikea customer service is certainly a good idea if nothing works. But often, the community here can help as well. What does the wood look like? Does the back panel slide smoothly into the groove?
Maybe you can apply some even pressure or try a small rubber pad at that spot to achieve a better fit?
The issue with mounting the back panel of the Ikea Besta system is well known and usually results from manufacturing tolerances in the pre-drilling. It is crucial to consider the following points:
- Check that all side panels are exactly square. Even a slight deviation can affect the position of the drill holes.
- The back panel is secured with thin dowel joints and screws. If the holes do not align, do not force the screws in, as this can damage the material.
- Pre-drilling with a 2–3 mm (0.08–0.12 inch) drill bit can help insert the screws cleanly without splitting the wood.
- Alternatively, the back panel should be adjusted slightly offset to use the existing holes.
In exceptional cases, contacting Ikea for a claim may be useful if the components prove to be defective.
In addition to the tips already mentioned, I would recommend the following points:
- Use a cordless screwdriver with torque control and tighten the screws only until they are snug to avoid damaging the material.
- Be careful not to bend the back panel, as this can make the entire structure unstable.
- If the material already shows cracks, it’s better to have the affected part replaced.
- When there are issues with fit, slight inconsistencies in the wood itself are sometimes the cause rather than the drill holes.
Precision when aligning the cabinet carcass is often underestimated.
