ᐅ Ikea Besta Kitchen Shelf – How Can I Build It Strong and Stable?
Created on: 7 Jan 2016 18:23
Anben46
Anben46
7 Jan 2016 18:23
Hello everyone, I am currently planning to install an Ikea Besta kitchen cabinet in my small kitchen and want to build it as strong and stable as possible. My main question is: Are there any specific assembly tips or useful techniques to make the Besta cabinet particularly sturdy so that it can easily hold heavy kitchen utensils and possibly household appliances without warping or becoming wobbly? I am also interested in potential reinforcements, suitable screws or wall plugs, adjustments for mounting on the wall or floor, as well as any useful custom modifications. I definitely want to avoid the cabinet bending or twisting under load. Does anyone have practical experience or recommendations on how to get the best stability and load capacity out of the Besta cabinet? Thanks for your advice!
Sinzar
7 Jan 2016 19:07
If you want maximum stability, be sure to use the supplied metal brackets for wall mounting. Level them horizontally before tightening the screws—this is essential. For heavy loads, longer screws and higher-quality anchors are also recommended. Check the type of flooring and wall condition, as this makes a significant difference.
Ixvin
8 Jan 2016 09:44
Hello Anben46, your question is really well formulated and shows that you’re thinking carefully! For a stable assembly of the Ikea Besta kitchen cabinet, I recommend the following steps:
- Be sure to use all supplied fasteners and tighten them securely, rather than just hand-tight.
- Always mount the cabinet to the wall, ideally using suitable wall anchors appropriate for the wall type (e.g., concrete, drywall).
- For extra stability, you can install angle brackets or small wooden reinforcements inside to prevent the cabinet from wobbling under load.
- Pay attention to proper load distribution—heavier items should preferably be stored in the lower section.
- Alternatively, you can also add additional support legs under the cabinet if the floor is strong enough to bear the load.
If you like, I can also give you some recommendations on tool choices and the best screws to use. Hope this helps you for now!
gekira
8 Jan 2016 11:28
The fundamental stability of the Ikea Besta kitchen cabinet mainly depends on correct wall mounting. The included metal brackets serve as the primary securing elements. It is important to use appropriate wall anchors according to the wall material (e.g., heavy-duty anchors for concrete, expansion anchors for solid brick) to optimize load-bearing capacity.
Additionally, stability can be improved by the following measures:
- Screwing the individual modules together in addition to the factory connections, for example, with reinforcement brackets
- Adding small wooden or metal cross braces at the back or bottom of the cabinet, if structurally possible
- Using screws with a larger diameter and higher strength than the original fasteners
Preventing tipping motions is further ensured by a tight fit against the wall and, if necessary, securing at the floor. Checking the alignment with a spirit level prevents distortions that can cause weakening over time.
Anben46
8 Jan 2016 16:53
Ixvin schrieb:
If you want, I can also give you some recommendations for tool selection and the best screws.
That would be great, thanks! Which screws do you think are particularly suitable if I want to primarily attach the shelf to a drywall-covered wall? Should I use special anchors or screws here, or would it be better to install additional reinforcements behind the wall?
Also, I am considering whether it makes sense to reinforce the shelves with extra strips under the front edge to prevent sagging under heavy load. Has anyone tested this or can share their experience?
