ᐅ IKEA BESTA – What is the maximum weight this furniture can support?
Created on: 31 Mar 2023 16:23
NASAN36
NASAN36
31 Mar 2023 16:23
Hello everyone, I am currently looking into the stability and maximum load capacity of the IKEA Besta furniture system, especially the cabinet and sideboard units, as I want to use them for TV and media furniture.
I am particularly interested in how much weight a single Besta unit, for example a shelf measuring 120 x 40 x 38 cm (47 x 16 x 15 inches), can actually hold without sagging or damage. Are there official IKEA specifications regarding the load capacity of the shelves and the entire construction? Real-life experiences with how much weight a fully assembled Besta has held for you would also be very helpful.
I plan to store heavy electronic devices such as receivers, larger speakers, and possibly decorations. The furniture should remain stable and show no weaknesses even after prolonged use.
Does anyone have tips for reinforcement or handling higher loads in case the standard load capacity is insufficient? Thanks in advance for your assessments and experiences!
Jeffon
31 Mar 2023 17:46
The question about the maximum load capacity of the IKEA BESTA system is quite valid, as this furniture is often used as a media unit. According to official IKEA product information, the load capacity varies depending on the component:
- Individual shelves usually support up to 25 kg (55 lbs) evenly distributed
- The entire unit can hold approximately 40–50 kg (88–110 lbs), depending on the number and type of shelf supports
These specifications, of course, only apply to normal, intended use with correct assembly.
It is important that the load is not concentrated in one point, as this can cause sagging. For heavier items, it is recommended to add additional stabilization elements, such as sturdy back panels or extra center supports.
User experiences from various groups show that many BESTA units can handle higher loads without problems under moderate use and on a proper surface. Nevertheless, it is essential to follow the maximum load guidelines outlined in the IKEA manual and to opt for reinforcement if in doubt.
A general recommendation: before loading, check the assembly and any existing connectors to ensure that the load is evenly distributed.
nojaus
1 Apr 2023 09:12
I can partly agree with Jeffon.
Jeffon schrieb:
The important thing is to avoid concentrating the load in one spot, as this can cause sagging.
That was exactly the problem I had. For example, I stacked heavy vinyl records on a BESTA shelf, and over time you could see the shelves bowing slightly. Not dramatic, but noticeable and annoying.
I then inserted a thin chipboard panel underneath to better distribute the load. Since then, the furniture has held up much better.
People often underestimate how long the load acts on such furniture. Even though IKEA states a capacity of 25 kg per shelf, under heavy continuous load, it can be beneficial to reinforce it slightly.
I’m interested to hear if anyone has experience with reinforcements for IKEA BESTA furniture that can be done easily and without major modifications.
TARAON
2 Apr 2023 11:08
I have been using my BESTA as a media furniture piece for almost 3 years now and I have to say: so far, it’s been great with no signs of weakness!
nojaus schrieb:
For example, I stacked heavy vinyl records on a BESTA shelf, and over time you could notice the shelves sagging a bit.
I can understand that, but with a bit of attention to detail, you can actually do a lot! I never fully loaded my shelves; I prefer to distribute the weight a bit more evenly. Also, small plastic feet or washers under the legs can sometimes help increase stability.
And honestly: who doesn’t know this? IKEA offers such a flexible range – sometimes it’s not 100% stable, but really practical! When storing heavy items, I always put something underneath or below – preferably something that spreads the pressure, which helps everything last longer.
Just stay relaxed and experiment, and if necessary, reinforce later. That somehow makes it all more likeable! 🙂
