á IKEA BESTA: How Can I Transform a Simple Cabinet into a Customized Storage Solution?
Created on: 16 Oct 2015 08:23
MaudoHello everyone, I bought an IKEA Besta basic box and am considering how to turn it into a custom storage solution that fits perfectly in my living room. My main questions are: How can I modify the box effectively to incorporate different inserts such as drawers, doors, or open shelves? Iâm also interested in which tools and materials are best suited to make this process as easy and sturdy as possible. Does anyone have experience with adapting BESTA components, maybe even with creative ideas for surface finishes or special fittings? I would appreciate tips on planning, execution, and advice on potential pitfalls in this DIY project!
Maudo schrieb:
How can I effectively modify the cabinets to incorporate different inserts like drawers, doors, or open compartments?The best approach is to mix and match the IKEA modules; itâs fun and keeps things flexible! I built my BESTA shelf using a combination of open compartments and drawers, with a little twist: magnetic strips mounted on the back wall for tools â super practical!
Maudo schrieb:
Iâm also interested in which tools and materials work best to make this process as simple and sturdy as possible. For the basics, a cordless drill, drill bits, and a good handsaw are enough. If you plan to paint, consider using acrylic paints or spray cansâthey provide a clean finish. Also, think about carabiners or fittings for that special touch.
piBenedi4116 Oct 2015 12:17I like how personalized furniture can be created from simple cubes. Often, people are unsure whether their ideas are technically feasible. At first, I was overwhelmed because I didnât know if the BESTA units were suitable for custom-designed drawers. Ultimately, the idea of starting small, testing, and then expanding helped me. Some steps are rough, but the pride when it works is great. So: donât get discouraged!
For customizing IKEA BESTA cabinets, I recommend the following structured approach:
- Define the functionality (type of storage, e.g., dishes, electronics, decorations).
- Measure the available space precisely and plan the installation so that standard BESTA modules can be combined.
- Use high-quality tools: cordless drill with matching bits, router for grooves, clamps for securing.
- For modifications such as installing custom drawers, use templates and precise drilling.
- For surfaces: use melamine resin coatings or laminates for durability. Painting requires sanding beforehand.
Consider the maximum load capacity of each module to ensure stability.
Wow, Maudo, the BESTA system is brilliant! You can really create so much with it! I built a media cabinet myself, with LED lighting inside â it looks really stylish! đ Donât get overwhelmed by too many ideas, start with one unit and experiment. And donât be afraid of the tools, itâs fun and gives you a real sense of power!
