ᐅ Ikea Besta – How Can I Reinforce the Furniture for Heavy Loads?
Created on: 1 Jan 2017 09:17
Bisau61Hello everyone,
I recently purchased the Ikea Besta system to use as a TV cabinet. I have a question: How can I stabilize the furniture so that it can easily handle heavy loads?
The Besta units seem to be built quite lightweight by design, and although the surface appears sturdy, I have concerns about the load-bearing capacity, especially when the furniture is loaded with heavy equipment like a large TV, amplifiers, and possibly heavy decorative items.
Specifically, I would like to know: What measures do you recommend to significantly improve stability and load capacity without affecting the furniture’s appearance or functionality? Are there proven tips for retrofitting stabilization elements or reinforcements that attach directly to the carcass?
It would also be interesting to know if there are differences in stability among the various Besta modules available and which models require extra caution.
I look forward to your tips and experiences!
ronAlberto1 Jan 2017 10:03Bisau61 schrieb:
What measures would you recommend to significantly increase stability and load-bearing capacity without limiting the furniture's appearance or functionality?This is a very good and important question, especially since the Besta system is generally designed with a relatively lightweight cabinet. If you want to safely carry heavy loads, I recommend a systematic approach:
- First: Always use the original wall mounting hardware from Ikea, as most instabilities result from insufficient wall anchoring. This greatly improves safety.
- Second: Inside the cabinet, you can add reinforcement strips. For example, attaching plywood strips with a thickness of 15-20mm (0.6-0.8 inches) to the interior sides significantly increases rigidity.
- Third: The Besta back panel is usually just a thin hardboard – here you can reinforce it or replace it with a prefabricated sturdy back panel made of MDF or plywood, which stabilizes the entire cabinet against torsion.
- Fourth: Screw multiple modules together and additionally glue them with wood glue to create a rigid unit.
- Fifth: Make sure that the feet or base properly transfer loads to the floor and prevent any tipping moments. Adjustable feet can be used if necessary.
Could you specify which modules you have installed and what the approximate total load will be? That would help provide more targeted recommendations.
Bisau61 schrieb:
Are there any proven tips for retrofitting stabilization elements or reinforcements that connect directly to the cabinet?Hey! You can really do a lot with the Besta. My favorite trick, which is also quite simple: just screw extra battens behind the back panel—that gives the whole thing a real "boost" in terms of stability. And if you like, you can glue and screw the individual parts firmly together—I did that, and since then my cabinet hardly wobbles at all.
Don’t worry, you don’t have to turn the furniture into a steel bunker. A few wooden battens and screws will really improve the Besta without affecting the appearance.
I also think it’s worth checking the feet, especially if you plan to put heavy equipment on it—the unit has to transfer the load to the floor; otherwise, nothing else helps much.
Good luck! 🙂
ronAlberto schrieb:
Inside the carcass, you can also install additional reinforcement strips. For example, multiplex plywood strips with a thickness of 15-20mm (0.6-0.8 inches) screwed to the inner sides significantly increase stiffness.This recommendation is technically very precise and to the point. Additionally, I would like to add that the load-bearing capacity also depends on the fastening of the individual modules. Use only metal screws with adequate torque and suitable diameter to prevent loosening under dynamic loads.
It is also important to ensure the load is distributed as evenly as possible. Concentrated loads in specific areas increase the risk of material fatigue.
In practice, the use of additional corner brackets inside has proven effective, improving torsional rigidity without affecting the appearance.
If possible, it should also be considered whether a base plate can be integrated to distribute the load over larger areas.
leteo schrieb:
Simply screw additional battens onto the back panel; this gives the whole thing a real boost in stability.Completely agree! I put a lot of effort into my Besta – extra battens are worth their weight in gold! And the best part: you only really notice it once you’ve loaded the furniture properly. No strange noises, no wobbling, just solid and secure.
If you want, add a wall fastener at the top, and the unit will be rock steady. I screwed all my modules together, which makes a lot of sense because individual units might otherwise shift.
All in all: go for it! The Besta is great for upgrades. Good luck and keep us posted!
