ᐅ IKEA Besta – How can I securely attach additional internal compartments?
Created on: 16 Aug 2019 17:23
Majetan
Majetan
16 Aug 2019 17:23
I am currently planning to outfit my IKEA Besta shelving unit with additional internal inserts to improve organization and clarity. However, I am concerned about how to securely and permanently attach these inserts so they don’t wobble or come loose over time. The inserts should not just be placed loosely but firmly fixed, so that frequent handling, like taking them in and out, doesn’t cause any issues.
Are there specific screws, brackets, or clamping mechanisms that have proven especially reliable? Or would it be better to use DIY solutions like additional angle brackets or strips? It is also important to me that the attachments can be removed later with minimal residue if the inserts are taken out.
Has anyone had experience with stable fastening of such internal inserts in the IKEA Besta? Which methods work well and which don’t? I would also appreciate advice on the best tools and materials to use for this.
Thanks in advance for any helpful tips!
Colby42
16 Aug 2019 18:47
Hey Majetan! Great question, I love upgrading my Besta furniture all the time! 😄
I screwed a few small brackets from the hardware store into the interior panels of my unit. They hold extremely firmly, and the best part is: if you work carefully, the mounts are barely visible. I’ve also sometimes used double-sided mounting tape for extra hold – it provides additional stability and leaves almost no marks when removed.
My recommendation: just use small, narrow brackets that you screw into the side panels or shelves. If you measure the shelf beforehand, you can get a really precise fit. It’s sturdy, looks neat, and can be removed without damage if you’re careful. And – problem solved! 🤗
barle
16 Aug 2019 19:03
Colby42 schrieb:
Simply use small, narrow brackets that you screw into the side walls/shelves.
Exactly, brackets are the most stable solution. It’s best to use corrosion-resistant screws for this. Alternatively, you can fix wooden blocks with glue if screws are not desired.
Fitigu
16 Aug 2019 21:36
For securely attaching additional internal inserts to IKEA Besta units, I recommend a structured approach:
- Measure and mark the drilling points directly on the inside of the shelf frame and the insert.
- Use small metal brackets, preferably galvanized or stainless steel, for long-lasting stability.
- Choose screws of appropriate length to avoid damaging the panels.
- Pre-drill holes to prevent the material from swelling.
- Alternatively, custom-sized shelf boards with clamps that do not require screwing can also be used.
The combination of metal brackets and pre-drilling ensures a solid fixation. Be cautious when using mounting materials that could leave residues, as is the case with double-sided tape or adhesive compounds.
GEKAU51
17 Aug 2019 09:12
Majetan schrieb:
The inserts should not just be loosely placed but properly secured so that stresses, such as from frequent removal, do not cause any issues.
I wonder if the pursuit of stability with IKEA parts always has to be so intense. The carcass materials simply aren’t designed to bear heavy loads.
True stability only comes from parts that are properly screwed or glued. But then you need tools and must accept that the furniture will be visually and structurally altered.
My provocative opinion: Systems should be used as intended. For more stability, I prefer custom-made interior solutions or sturdier furniture from the start. Everything else is a waste of time and just a DIY hack.
JONKO
17 Aug 2019 11:29
I understand the uncertainty about fastening very well, especially if you want to keep the piece of furniture flexible in use.
GEKAU51 schrieb:
Only what is properly screwed or glued is really stable.
That may sound harsh, but there is some truth to it. That’s why I rely on small brackets fixed with water-soluble adhesive – so if I want to rearrange the shelf later, I can relatively easily remove the supports. It’s a compromise between stability and flexibility.
I was also interested in how others handle this. Thanks to everyone for the tips; I will probably try a combination. The approach with pre-drilling and screwing sounds especially sensible.
