Hello everyone, I recently bought the Ikea Besta shelving unit and now I’m a bit concerned about the risk of tipping. The unit is quite tall and is placed in a room where children often spend time. My question to you is: What is the best way to secure the Ikea Besta shelving unit against tipping, so it remains stable even under load or if it gets bumped? I would appreciate tips on how to attach it to the wall, which materials are suitable for this, and if you have any experience with specific safety systems. Additionally, I’m interested in any particular points to consider during installation to effectively eliminate the tipping hazard. Thanks in advance for your advice!
I would recommend purchasing anti-tip kits specifically for children's wardrobes and shelves. Ikea usually offers kits that can be easily attached to the wall. It is important to install them as high up as possible. Additionally, make sure that the screws are anchored in the wall studs or other structural parts of the wall.
For a secure installation of the Ikea Besta to prevent tipping hazards, the following steps are essential:
- First, accurately identify the wall material: concrete walls require anchors suitable for the load, while drywall (gypsum board) must be fitted with hollow wall anchors that provide sufficient load-bearing capacity.
- Do not use the fastening materials included in the furniture package; instead, purchase high-quality screws and anchors.
- Fastenings should always be placed close to the upper edge of the unit to minimize leverage forces that cause tipping.
- For larger modules, securing at multiple points is recommended.
- Adhering to the maximum load capacity further reduces the risk of tipping.
Common mistakes include:
- Using universal anchors that do not provide safety in drywall applications.
- Mounting in areas of the wall that lack structural strength.
- Uneven weight distribution within the shelving unit.
Proper installation is straightforward, but careful attention is essential.
sonrickey15 Feb 2015 10:11I think it’s important not to overcomplicate things, but to take them seriously. 😄
Exactly! Investing a little more than the standard kit gives you real security and makes everyday life more relaxed.
Also: Small helpers like furniture drawers with soft-close mechanisms or doors that close gently protect the shelving unit and reduce the risk of tipping when nothing moves suddenly. You don’t want the shelf wobbling at every slight touch.
Conclusion: Secure wall mounting, good anchors, and maybe a bit of “childproofing” in terms of load—then the Besta will stay right where it belongs! 😉
Tarbi schrieb:
I would recommend not relying solely on the original fasteners, but adding extra support with suitable heavy-duty anchors and high-quality screws.
