ᐅ IKEA BESTA: How can I remove adhesive residue without causing damage?
Created on: 8 Oct 2018 08:37
guken
guken
8 Oct 2018 08:37
I have a problem with stubborn adhesive residues left on the surface of my IKEA Besta furniture after removing the protective films. I am looking for a way to remove these residues without damaging the painted surface or the material. Which methods or products would you recommend that are effective yet gentle enough to avoid scratches or discoloration? Could you also share any experiences with specific household remedies or specialized cleaners, preferably with a brief explanation of how you applied them? Thank you in advance!
Pome60
8 Oct 2018 09:12
Hey guken,
I had exactly the same problem with my BESTA! The adhesive residue just wouldn’t come off. My method was a bit of patience and the following steps:
- First, I gently warmed the adhesive residue with a hairdryer to soften the glue a little.
- Then, I carefully scraped off the bulk using the edge of a plastic card.
- Finally, I took a cloth with a small amount of isopropyl alcohol and rubbed gently.
This worked great for me without causing any damage! But be careful—use only a very small amount of alcohol and always test on an inconspicuous area first.
Don’t give up, it works! 😊
SUBEN60
8 Oct 2018 11:23
Pome60 schrieb:
I first gently warmed the adhesive residue with a hairdryer, which softens the glue a bit.
This is a useful tip for preparation.
In addition, I recommend the following approach:
- Use low-concentration isopropanol or acetone-free nail polish remover, as acetone can damage the surface.
- Always test on a hidden area to avoid changes in color.
- Use a soft cloth, avoid abrasive sponges to prevent scratches.
- Remove mechanically with a soft plastic scraper or a credit card, never metal.
This method is researched and based on practical experience to prevent damage to the melamine-coated or painted surfaces of IKEA furniture.
For extremely stubborn adhesive residues, a special low-solvent adhesive remover can be used, but please carefully check the product information.
Demetrius
9 Oct 2018 07:45
guken schrieb:
Which methods or products can you recommend that are effective but gentle enough to avoid scratches or discoloration?
I understand how frustrating it can be to remove adhesive residue while worrying about damaging the furniture.
In my experience, hemp oil or olive oil works very well as a gentle option. Simply apply a little oil to a soft cloth and soak the adhesive residue. After a few minutes, you can usually rub it off with light movements, without using harsh chemicals. It takes some time, but it’s very gentle.
It’s important to wipe the furniture afterwards with mild soapy water to remove any oily residue.
I hope this method is helpful for you too!
