I have been using an IKEA Besta sideboard for some time, mainly as a TV stand. Although I assembled it very carefully, over time I notice increasingly annoying wobbling, especially when it is lightly bumped or when moving small loads. The construction seems stable, but obviously, use and load cause some components to loosen slightly or the base surfaces not to sit perfectly.
I am therefore specifically interested in which measures can help prevent or minimize wobbling after extended use. This is a known issue with BESTA systems, as the individual modules and legs are often held together only with connector screws and simple fasteners.
Are there any proven tips involving special assembly materials, adjustments, or additional additions (e.g., brackets, shims) that can stabilize the furniture structure permanently?
I look forward to your practical experiences and advice, especially regarding long-term solutions that effectively avoid repeated adjustments or wobbly modules.
Thanks in advance!
Thanks in advance!
Hello Luisso,
I completely understand your question and have studied the stability of IKEA BESTA systems thoroughly, as I own several models myself. The wobbling usually results from the interaction of connectors, screws, and the floor as the base.
The following points help ensure long-term stability:
- Regularly check whether all so-called "cam lock connectors" are properly engaged and tight. These tend to loosen under load.
- Additional angle brackets from a hardware store at critical joints provide extra stability, especially for longer sideboards.
- BESTA feet often only allow height adjustment but are not necessarily secured against tipping. Rubber pads or small wedges help to precisely level the feet.
- Screws should be tightened with appropriate torque but not over-tightened to avoid damaging the material.
Finally, I ask: where exactly do you notice the wobbling? Is it the entire piece of furniture, a specific connection, or the feet? These details would help suggest the perfect solution.
Filippo schrieb:
Finally, I ask: Where exactly is the wobbling for you? Is it the entire piece of furniture, a specific joint, or the legs?This is an important question. Without targeted analysis of the weak point, it is difficult to address the problem effectively.
In general, for BESTA systems, it makes sense to check the following measures:
- Level the furniture using a spirit level to rule out uneven flooring.
- Inspect and, if necessary, shim the legs so that the contact area fully touches the floor.
- Check the fasteners (cam locks) for looseness.
Especially the combination of uneven floors and slightly loose connecting elements often causes wobbling.
Maria35 schrieb:
This is an important question. Without a targeted analysis of the weak point, it is difficult to address the problem efficiently.Thank you for the advice. In my case, the furniture wobbles mostly at the connecting points between the individual modules or when I slightly shift the sideboard as a whole. The feet stand firmly on the floor, and I have used a spirit level, so the floor is quite even.
I suspect that the cam fittings have some play and that the screws may loosen over time.
Are there any specific products, such as thread lockers or technical aids, to keep the threads or connections permanently stable without having to constantly retighten?
And what about additional brackets – at which points in the BESTA system would installing them be most effective to secure the overall structure sensibly without significantly affecting the appearance?
Luisso schrieb:
Are there any specific products, such as thread lockers or technical aids, to keep the threads or connections permanently stable without having to constantly retighten?Yes, for securing screws, thread-locking adhesives (e.g., medium-strength threadlocker) work well. These prevent screws from loosening due to vibration or load. Additionally, you can use thin felt strips or foam padding in the joint areas to cushion slight movements and stabilize the connections.
Luisso schrieb:
What about adding extra brackets—at which points in the BESTA system would attaching them be most effective to reinforce the overall structure without significantly affecting the appearance?Small, discreet brackets placed inside at the end faces of the modules where two or more parts connect are recommended. This noticeably improves the connection without altering the overall design. Make sure the brackets are flat and preferably painted or finished to match the furniture’s wood appearance so they remain unobtrusive.
