ᐅ Ikea BESTA – How can I prevent the doors from warping during the summer?
Created on: 18 Nov 2024 08:23
moboon
I have a specific issue related to the Ikea Besta system and would like to draw on your expertise: How can I prevent the doors of my BESTA cabinets from warping in summer?
My doors are made from the standard MDF variant coated with a foil finish, and they tend to warp slightly with high humidity and heat, causing the doors either to no longer close flush or to lift at the corners. This affects not only the appearance but also the functionality significantly.
I have already considered whether this is due to a lack of ventilation inside the cabinet carcasses, or if additional measures might be helpful, such as extra sealing, a dehumidifier in the room, or special hinges.
I am especially interested if anyone has experience with this issue, can offer prevention tips, or perhaps even knows a reliable and practical solution that goes beyond purely cosmetic fixes.
Thank you in advance for your opinions and suggestions!
Filippo
20 Nov 2024 07:26
moboon schrieb:
Are there any recommendations on how to best remove and reinstall the doors to avoid damaging the film?
Good question! Here are some practical tips for removing doors from Besta:
- Use a soft surface, such as a blanket or large towel, to carefully lay the doors down so the film surface does not get scratched or damaged.
- IKEA Besta hinges are usually secured with quick-release fasteners that can be opened by pressing with your thumb. Apply gentle pressure, avoid pulling strongly.
- If possible, remove the doors with the help of a second person, especially the larger or wider ones, to prevent warping.
- When reinstalling, carefully hook and adjust the hinges, paying particular attention to the height adjustment to align the doors flush.
Regarding drying the paint layers:
- Water-based PU paints require at least 4-6 hours drying time per thin coat, ideally 12 hours for complete curing.
- Usually, 2-3 thin coats are sufficient for good protection.
- It’s best to let the doors fully dry before reinstalling – with some planning, this can be done within 2-3 days.
- A dust-free, well-ventilated environment is important for drying.
Hope this helps!
nubar
20 Nov 2024 09:33
I would like to add that in addition to the measures mentioned, you should also pay attention to the general humidity level in the room.
- Dehumidifiers are a good recommendation, especially in poorly ventilated or damp rooms.
- You can also try to avoid placing doors or cabinet units directly next to radiators or poorly insulated windows, as these heat sources can increase temperature fluctuations.
- Additionally, choosing alternative door materials when purchasing new or replacement items can be a long-term solution: fronts made of HPL (High Pressure Laminate), for example, absorb much less moisture and remain more dimensionally stable.
Unfortunately, a comprehensive solution is only partially realistic without considering the influence of the indoor climate.
