ᐅ Ikea BESTA – How can I prevent the doors from warping during the summer?
Created on: 18 Nov 2024 08:23
moboon
moboon
18 Nov 2024 08:23
I have a specific issue related to the Ikea Besta system and would like to draw on your expertise: How can I prevent the doors of my BESTA cabinets from warping in summer?
My doors are made from the standard MDF variant coated with a foil finish, and they tend to warp slightly with high humidity and heat, causing the doors either to no longer close flush or to lift at the corners. This affects not only the appearance but also the functionality significantly.
I have already considered whether this is due to a lack of ventilation inside the cabinet carcasses, or if additional measures might be helpful, such as extra sealing, a dehumidifier in the room, or special hinges.
I am especially interested if anyone has experience with this issue, can offer prevention tips, or perhaps even knows a reliable and practical solution that goes beyond purely cosmetic fixes.
Thank you in advance for your opinions and suggestions!
Filippo
18 Nov 2024 10:58
Hello moboon,
First of all, a very good and clear question regarding the BESTA doors and their warping in summer, since MDF materials are very sensitive to moisture and temperature fluctuations. I will go through possible causes and solutions step by step:
- Material-related swelling: MDF tends to absorb moisture. Although the surface is laminated, the MDF underneath can swell in high humidity.
- Lack of ventilation: If the cabinet boxes are completely closed, heat and moisture can build up behind the doors, which promotes warping.
- Temperature fluctuations: Especially in summer, the combination of direct sunlight and humidity can stress the doors.
What you can actively do:
1. Optimize indoor ventilation: Make sure there is air circulation behind and inside the cabinets, for example through small ventilation slots or by leaving a gap from the wall.
2. Climate control: An indoor climate with a constant relative humidity of around 50% is ideal. A dehumidifier is very helpful when values are higher.
3. Sealing the back sides: Some users recommend sealing the back side of the doors with a thin layer of clear varnish. This reduces moisture absorption and minimizes warping.
4. Hinges and adjustment: High-quality hinges with adjustment options make it easier to readjust the doors if warping occurs despite all measures.
My question: Are your BESTA doors already treated with a special sealant, or do you handle them only with the standard laminate? And do the fronts receive direct sunlight? The more details you provide, the more precise we can help you.
nolan
18 Nov 2024 11:42
The most effective way to help is regular ventilation and avoiding placing cabinets directly against exterior walls, where high humidity often occurs. Additionally, treating the doors with a bit of furniture wax can reduce swelling.
moboon
18 Nov 2024 13:15
Filippo schrieb:
My question: Are your BESTA doors already treated with a special sealant, or do you just handle them with the standard foil? And do you have direct sunlight on the fronts? The more details, the better we can assist you.
Thanks, Filippo, for the detailed response. The doors are actually only covered with the standard foil coating, no additional sealant or paint. The cabinets are located against an interior wall without direct sunlight, but the room tends to get quite warm and humid in the summer due to the large windows.
I will try to see if I can improve ventilation soon, as you suggested. The clear coat for the backs sounds interesting – do you have any recommendations on which type works best (water-based, heat-resistant, etc.)?
Palenar
19 Nov 2024 09:07
Hello moboon,
I would like to add to the previous points with some additional details, especially regarding the sealing of the doors:
- A thin layer of water-based PU (polyurethane) varnish works well because it is flexible, should be applied in thin coats, and remains breathable. This reduces shrinking and swelling caused by moisture without sealing the doors completely and causing stress.
- When varnishing, make sure to seal all sides of the door—not just the front but also the back and edges—since moisture often penetrates there.
- Lightly sand the surface before varnishing (using fine sandpaper, grit 220-320) to improve adhesion.
- Important: The doors should be dry before varnishing, and the treatment should be done in multiple thin layers, allowing enough drying time between coats.
Regarding ventilation:
- You might consider placing the cabinet boxes on small spacers to create a gap from the wall and ensure ventilation underneath.
- Also, check if the back panels of the BESTA cabinets are firmly attached and not transferring moisture to the back of the doors.
One technical note:
The standard BESTA doors are made of coated MDF with edge banding. This construction is mechanically less stable than solid wood or solid core doors. If warping occurs frequently and severely, it might be worth considering additional reinforcements—such as internal aluminum supports or supplementary crossbars, if possible.
If you’re interested in more details about varnish selection or application, I’m happy to provide further technical information.
moboon
19 Nov 2024 12:38
Palenar schrieb:
A thin layer of water-based polyurethane (PU) varnish works well because it is flexible, can be applied in a thin coat, and remains breathable.
Thank you very much for the additional advice! It really helps me a lot. Until now, I had simply thought of an extra coating in general, but I wasn’t aware of the differences between varnish types.
The idea of lightly sanding before painting sounds logical. Also, I have mostly only wiped my doors superficially so far, without fully drying them before storage — I will keep that in mind going forward.
Are there any recommendations on how to best remove and reinstall the doors to avoid damaging the film? And what is the typical drying time window for the varnish layers? I would prefer not to have all the doors dismantled and stored for months.
