I am currently assembling my new Ikea Besta cabinet and am having trouble with the back panel. The instructions show how to generally insert the back panel, but for my model, it is larger than the actual opening for the back panel, and I am unsure how to properly secure it to keep the cabinet stable and prevent any wobbling.
Should the back panel be nailed or glued somewhere before assembly? Or is it simply inserted between the cabinet carcass and the back? Are there any special brackets or fasteners I might have missed?
I would really appreciate a detailed explanation or tips on how to correctly and permanently secure the back panel, especially for the Ikea Besta series. Thanks in advance!
daalessio23 Jun 2023 14:07Hello reopin,
to elaborate a bit more on your question: The back panel of cabinets like Ikea Besta primarily provides lateral stability and fulfills this function when it is installed flat and without stress.
Therefore:
- Insert the back panel so that it fits exactly into the designated grooves.
- Avoid forcing or bending the back panel when installing it.
- The small nails are only meant to hold the back panel in place, not to tension it.
- If the fit is not 100%, applying light pressure on the surface can help, but do not deform it.
A tip: If the cabinet still wobbles after assembly, check whether all joints (side panels, shelves, back panel) are properly secured. Sometimes the problem is missing or incorrectly installed corner brackets or connectors.
A back panel can be reinforced with brackets or screws if stability is weak in individual cases. But normally, the original nail fastening is sufficient.
Therefore:
