ᐅ IKEA Besta – How Do I Install New Handles Myself?
Created on: 24 Dec 2023 14:17
Kenraul
Hello everyone, I recently bought an IKEA Besta sideboard and now want to replace the existing handles with new ones. My question is: What is the best way to attach these new handles to the fronts myself? I have already noticed that the Besta fronts have pre-drilled holes, but I’m unsure if I can simply screw on the new handles or if there is something else I need to consider, such as drilling or screw length. I would also like to know if any special tools are required or if a simple screwdriver is sufficient. I would appreciate any tips on preparation and aligning the handles so that everything fits neatly and securely. Thanks in advance for your help!
RENMA
25 Dec 2023 14:59
Kenraul schrieb:
Also, I would like to know if I need any special tools or if a simple screwdriver is sufficient.
In most cases, a standard Phillips screwdriver is sufficient.
Depending on the type of handle and screws, a cordless drill with low speed can help to avoid damage to the wood.
If new holes are required, a drill with a small bit (approximately 3-4mm (0.1-0.16 inches) diameter) is useful, but be careful to avoid misdrilling.
Kenraul
26 Dec 2023 09:18
Thanks for the helpful information so far! Regarding screw length: Can anyone recommend how to determine the correct length when buying new handles with different spindle thicknesses? Is it enough to simply measure the thickness of the front panel with a ruler and add 5 mm (0.2 inches) for the screw? Or is there another, more reliable method?
And one more question: Is it really advisable to remove the front panel, or can this be done directly on the furniture? I’m concerned that holding it might easily damage the front panels.
