ᐅ IKEA Besta – How Do I Install a Soft-Close Mechanism on the Door?
Created on: 2 Aug 2024 10:33
redarrel38
Hello everyone, I am planning to add soft-close dampers to the doors of my Ikea Besta shelving unit because the doors currently close quite hard, and the noise bothers me a bit. I would like to know the best way to install door dampers without causing significant damage to the existing hinges or the door. Are there specific dampers that are easy to install? Also, what is the best position for the damping elements – should they be attached to the door frame or to the cabinet body? It is also important for me to know whether I need to consider the typical Ikea Besta rail system during installation, or if there are universal dampers that work well and are discreet. I look forward to tips and suggestions from you, especially regarding which parts you recommend and any advice on installation if anyone has done this before.
Marcellela
4 Aug 2024 08:19
Buy a soft-close hinge, remove the old hinge, and install the new hinge. Done. The most common models are compatible with Ikea Besta.
Important: Screw holes must match. Installing a door damper separately often involves more effort without real benefit.
Davidleo
4 Aug 2024 14:45
I installed the soft-close dampers on the Besta just two weeks ago – really satisfied! No more slamming noises, and the doors close completely quietly and smoothly. Just remove the old hinge, put in the new one, done! So if anyone is still unsure: definitely worth it!
Really great, the upgrade is a lot of fun!
redarrel38
5 Aug 2024 10:00
Davidleo schrieb:
I installed soft-close dampers on my Besta units just two weeks ago – extremely satisfied! No more banging sounds, and the doors close very quietly and smoothly. Just remove the old hinge, install the new one, and you’re done! So if anyone is still unsure: it’s definitely worth it!
Thanks for your feedback! That sounds exactly like what I was looking for. I will now look for soft-close hinges and try to install them precisely. If I run into any issues, I’ll get back to you.
Thanks to everyone for the helpful tips and suggestions!
