ᐅ IKEA BESTA: How can I build a high-load capacity combination?
Created on: 27 Aug 2018 08:37
siegbertkiS
siegbertki27 Aug 2018 08:37I am planning to build an IKEA BESTÅ combination with especially high load capacity, as it needs to support some heavy appliances and various decorative items. My specific question is: What measures and technical resources can I use or additionally install to increase the load-bearing capacity of the individual modules and the entire combination without significantly deviating from the original design? I am particularly interested in tips regarding suitable fasteners, shelf reinforcements, connectors, or other modifications that make the assembly more stable and secure, while still being as easy to implement as possible. It would also be helpful to know if certain combinations of module sizes or designs are better suited than others to optimize load distribution. I look forward to your well-founded recommendations!
REOHEINRIC27 Aug 2018 10:13To increase the load capacity of an IKEA BESTÅ combination, I recommend the following proven approach:
- Use only the thicker or reinforced shelves from the BESTÅ series for heavier loads, as standard shelves may bend under high weight.
- Install additional center supports to reduce the shelf span.
- Ensure a secure wall attachment using the supplied wall anchors, as the stability significantly contributes to load bearing.
- Avoid overly long units without center support, as these can weaken the overall stability.
- If necessary, reinforce the construction with sturdy metal brackets inside to reduce shear forces.
- Check the connecting fittings (RAMHULT or METOD screws) and, if needed, support them with wood glue.
Combining several smaller modules with balanced load distribution is more effective than using a few large ones that are heavily loaded in specific spots.
It is important that you always use wall mounting and do not overload freestanding cabinet units. Use extra strong shelves and add reinforcements underneath the shelves. Connect modules with angle brackets for increased stability. Shorter shelves support more load than longer ones.
REOHEINRIC schrieb:
A combination of several small modules with coordinated load distribution is more sensible than a few large ones that are heavily stressed at certain points.Great tip – that hits the mark exactly! ?I once built a BESTÅ combination designed to hold a large number of books plus a hi-fi system. Instead of organizing this with a single large unit, I placed two smaller units side by side and connected them with metal brackets. This made the load capacity really stable.
Also, don’t underestimate the importance of the wall mounting hardware included! One wrong step there, and any weight class can become risky.
One more thing: If you value high load capacity, go for the thicker shelves. The standard shelves look nice, but in my experience, they tend to bend a bit over time, which is not only unsightly but can also be dangerous in the long run.
And don’t be afraid of screws and brackets! With a bit of experience using tools, everything will be solid and durable. Good luck with your project!
