ᐅ IKEA BESTA - How do I assemble this furniture correctly without the instruction manual?
Created on: 4 Mar 2023 18:27
femoduI recently bought an Ikea BESTÅ furniture unit, but unfortunately, I can no longer find the assembly instructions. Is there anyone here who is familiar with the BESTÅ system and can explain to me step by step how to assemble this piece of furniture correctly without the original instructions? It would be particularly helpful to have guidance on the proper order for assembling the individual parts, such as the frame, the back panel, and the doors. If someone could also share tips on common pitfalls, that would be very useful to ensure I end up with a stable and neat piece of furniture.
flo-Theres5 Mar 2023 07:58I recommend sorting all the individual parts first and checking the connections using the pre-drilled holes. The basic structure is formed by connecting the bottom, top panel, and side walls with the included dowels and screws. Pay special attention to aligning the back panel cleanly and straight, as it significantly affects stability. Doors and drawers should be attached last to avoid compromising the overall stability. It is also important to choose a suitable surface to prevent the furniture from getting scratched during assembly.
Wow, building without instructions sounds like an adventure for DIY enthusiasts! 😉 Basically, the BESTÅ is cleverly designed, so start by assembling the basic frame – the base panel, top panel, and two side panels – then add the back panel, which provides good stability. When installing the doors, don’t use too much force, or they might get stuck later. And hey, if you’re not very handy, get a friend to help – working together is easier and more fun. That way, your stylish furniture will be ready quickly and last a long time.
baupau schrieb:
First, attach the side panels to the bottom and top boards, then insert the back panel. That is basically correct, but I want to point out that with the BESTÅ, the back panel is usually not just inserted but also fixed with small nails or staples. Simply inserting it is not enough for stability. Also, be careful with the screws, as the pre-drilled holes are often quite thin, which can cause material damage if overtightened.
KNUTGI schrieb:
When installing the doors: don’t use too much force, or they will stick later. To add to that: The hinges are adjustable. If the doors don’t close properly, you can usually fine-tune them with small adjustment screws, which is often mentioned in the official instructions. Without the instructions, it is helpful not to overlook this point to avoid misalignment and uneven gaps.
