Hello everyone, I recently assembled an IKEA Besta shelving unit and am now wondering about the best way to securely fasten the back panel. The back panel itself is made of thin hard cardboard material and is meant to stabilize the unit and prevent it from twisting. I definitely want the back panel to be firmly fixed, with no wobbling or loosening over time. What options are there to additionally secure the back panel? Are there special screws, clips, or recommended methods that provide more stability than the standard IKEA solution? I appreciate any practical tips or experiences on how others have securely attached their Besta back panels.
klaelmira28 Jun 2023 13:57Palenar schrieb:
For the metal brackets: use flat, small brackets up to 2 cm (1 inch) wide, which you attach on the inside corners of the upper cabinet frame. This way, they remain invisible from the outside. That sounds reasonable. My cabinet has a strip at the back on top that serves as a support. The suggestion to mount the brackets on the inside corners of the cabinet frame should work well. I will make sure to drive the screws carefully to avoid tearing the cardboard. Attaching to the wall would be ideal, but my room doesn’t have suitable wall studs, so I want to solve it without wall mounting if possible.
In summary, for attaching the thin Besta back panel: - Purely mechanical fastening with nails or staples is not sufficient, as the cardboard can tear. - Applying wood glue or spray adhesive across the entire surface significantly increases stability. - Metal brackets in the upper inner corners, preferably flat and discreet, help stabilize the structure. - Pre-drilling the screw holes in the back panel is essential to prevent damage to the cardboard. - If possible, wall mounting should be used as an additional measure. This combination provides a long-term stable solution without compromising the appearance. Question: Do you use original Besta back panels, or have you possibly installed MDF back panels as a replacement? This affects the fastening options.
klaelmira29 Jun 2023 19:10pikin schrieb:
Question: Are you using the original Besta back panels, or did you maybe install MDF back panels as a replacement? I used the original thin hardboard back panels. MDF was not an option for me because I prefer back panels that are reversible or the typical lightweight material. Thanks for the tips about gluing and using metal brackets—I will try it exactly like that. If I encounter any issues attaching the brackets, I will get back to you. Thanks to everyone for the advice!
