ᐅ IKEA Besta – How can I securely attach the back panel?
Created on: 27 Jun 2023 08:17
klaelmira
klaelmira
27 Jun 2023 08:17
Hello everyone, I recently assembled an IKEA Besta shelving unit and am now wondering about the best way to securely fasten the back panel. The back panel itself is made of thin hard cardboard material and is meant to stabilize the unit and prevent it from twisting. I definitely want the back panel to be firmly fixed, with no wobbling or loosening over time. What options are there to additionally secure the back panel? Are there special screws, clips, or recommended methods that provide more stability than the standard IKEA solution? I appreciate any practical tips or experiences on how others have securely attached their Besta back panels.
warrenka57
27 Jun 2023 09:04
That’s a very good question, klaelmira. I have a Besta at home myself and always found the back panel a bit wobbly. It was important to me that the shelf is really stable, especially when loaded with books or electronic equipment. What helped in my case was securing the back panel further with small nails, in places where the material allows it. There are special clips available, but in my opinion, nails provide a better, more solid hold. Of course, you need to be careful not to split or break the back panel. How is the surface where your shelf stands? That can also affect stability.
farGlen
27 Jun 2023 09:29
To securely attach the back panel, I recommend: - fixing the thin back panel at the edges with small nails - applying wood glue additionally for better adhesion - if possible, installing metal brackets on the inside corners. This will increase stability.
Laukau5
27 Jun 2023 15:22
Basically, when attaching the back panel of an IKEA Besta unit, it depends on which type of back panel is installed and how the shelving unit is used. Standard thin cardboard back panels are usually fixed to the carcass with small staples or nails, providing only minimal lateral support. For a truly secure attachment, I recommend the following procedure: - First, carefully remove the factory-installed fasteners. - Then, apply wood glue evenly across the entire back panel and press it firmly onto the back edges of the side panels. This ensures a strong bond and prevents wobbling. - Additionally, thin finishing nails can be gently nailed into the edges, but be careful to avoid splitting the material. - If the shelving unit is placed on uneven floors or will bear heavier loads, I also recommend installing metal brackets at the upper inner corners to stabilize the entire system. This prevents the unit from twisting over time or the back panel from coming loose. I am also curious: Do you use the shelving unit as a TV stand, a bookcase, or for other purposes? This can significantly affect the load and thus the effort needed for securing it.
klaelmira
27 Jun 2023 16:45
Laukau5 schrieb:
I’m curious: Do you use the shelving unit as a TV stand, a bookshelf, or for something else?
I use the Besta as a TV stand with a few electronic devices and some decoration. The shelving unit stands fairly stable on parquet flooring, but it is not directly fixed to the wall. The back panel is the thin cardboard type, not MDF or a wooden board. My aim is to prevent the unit from warping over time. Metal brackets in the inner corners are an interesting idea. What is the best way to attach them without compromising the aesthetic design?
Palenar
28 Jun 2023 10:03
Since you are using the Besta as a TV cabinet and the back panel is made only of thin fiberboard, stability is especially important. I would recommend the following approach: - First, align the back panel and glue it to the rear of the side panels using spray adhesive or wood glue. - Then, insert small nails or staples, using pre-drilled holes to avoid damaging the fiberboard. - For the metal brackets: use flat, small brackets with a maximum width of 2 cm (0.8 inches), attaching them to the inside of the upper corners of the cabinet. This way, they remain hidden from the outside. - Mount the brackets with small wood screws into the cabinet sides (pre-drill) and into the back panel where possible. - Additionally, attaching the unit to the wall is advisable if possible, as the shelf could otherwise tip over when used as a TV cabinet. It is important to carefully align the brackets and screws to prevent distortion. Do you already have exact measurements, or can you say if your Besta model is stable enough to hold such brackets?
