Hello everyone, while assembling my Ikea Besta cabinet, I noticed that some of the intended brackets (for example, the small metal angles or hanging tabs) are missing. The exact model size is Besta 800 x 1200 mm (31.5 x 47.2 inches), and mainly the brackets that are supposed to secure the shelves are affected.
Has anyone had experience with practical ways to replace such missing brackets without compromising the stability or appearance of the furniture? I would, of course, prefer to order original parts, but Ikea can sometimes be less accommodating with older models. In the meantime, I am looking for pragmatic replacement solutions—ideally something available at a hardware store or easy to make myself.
I would appreciate your specific tips or advice on proven alternatives. It would be helpful if you could also comment on any load limits or installation effort involved with your recommendations. Thanks in advance!
USORGES schrieb:
Does anyone have experience on how to properly replace missing brackets like these without compromising the stability or appearance of the furniture?Hello, the easiest solution is to use metal corner braces available at hardware stores, which serve the same purpose effectively. Look for small metal brackets with matching screws that can be discreetly fixed inside next to the joint. Visually, they are hardly noticeable and also strong enough. Important: use screws that are not too long to avoid damaging the material.
USORGES schrieb:
Of course, I would like to order original replacement parts, but IKEA is sometimes less accommodating with older models, so in the meantime I am looking for practical alternatives—preferably something available at a hardware store or easy to make myself.Original replacement parts are often missing, especially for older Besta series. As an alternative, I recommend the following approach:
- Use galvanized steel brackets from the hardware store, preferably sized 15-20 mm (0.6-0.8 inches).
- Choose screws matching the thickness of the wood (diameter 3-4 mm (0.1-0.15 inches), length about 12-15 mm (0.5-0.6 inches)).
- Mount the brackets on the inside of the shelves and cabinet sides to ensure stability even after assembly.
- If appearance is important, more delicate plexiglass or plastic holders can be used.
The load-bearing capacity of these alternatives is comparable to the IKEA supports under normal use. Important: pre-drilling into the wood is recommended to avoid splitting.
Additionally, a small wooden wedge can be fixed behind the shelves if pressure marks from the brackets are a concern.
GU-LAU60 schrieb:
Visually, they are hardly noticeable, and they are also load-bearing. Well, the brackets are usually not completely invisible. If you want flawless furniture, it’s better to use custom-made supports or try to find replacements at IKEA – maybe there are similar models available in the store or through forums.
Juan31 schrieb:
If appearance is very important, you can use more delicate acrylic or plastic supports. That sounds like a reasonable compromise, but acrylic can break easily if the load is too high. Plastic supports really need to be of high quality. Or you could consider trying completely new fixing methods, such as magnets or clips, even if these are not originally intended by IKEA.
I think the DIY aspect is often underestimated here: you can turn the supports into a small design statement by deliberately making them visible and maybe using contrasting colors. So why hide behind the official parts when you can customize the furniture that way?
From a practical point of view: what load do you actually want to carry? That often determines whether you even need replacement supports or if direct floor support is sufficient. Are there any experiences here?
