ᐅ IKEA BESTA – How can I repair damage to melamine surfaces myself?
Created on: 18 Dec 2023 09:17
mejabar
Hello everyone, I have an Ikea Besta sideboard with a melamine coating, and unfortunately a small corner has been damaged. The coating has a noticeable chip or scratch, and I would like tips on how to repair this damage myself without having to re-laminate or repaint the entire piece. Are there proven methods or materials to fix melamine surfaces without professional equipment? I am looking for durable solutions that are visually appealing and make the damage as invisible as possible. Thank you in advance!
Filippo schrieb:
I’m interested: How large is the damaged area exactly, and is it more of a surface that is driven over or a side edge? This can influence the choice of repair method. Thank you for the detailed answer. The damaged spot is a corner at the top of a door, about 2 cm² (0.3 square inches) in size, so not very extensive. The door opens and closes normally; this corner is only visually damaged.
klo61 schrieb:
I would also like to know from you how large the damaged area is and whether it is heavily stressed? Exactly as Filippo described. The surface is not subjected to extreme daily stress, but the door is moved several times a day. I want to avoid the repair spot being damaged again after a short time.
mejabar schrieb:
The damaged area is a corner at the top of a door, about 2 cm² (0.3 square inches) in size, so not very extensive. The door opens and closes normally; only this corner is cosmetically damaged. Thank you for the details! In this case, I would definitely recommend a two-component epoxy resin. It adheres very well to particleboard and melamine due to its strong bonding properties, is durable against mechanical stress, and can be finely sanded and polished after curing. Accurate color matching is important: you can either use a clear resin and carefully mix in color pigments or use colored repair kits.
If you have no experience with this, testing a small area first to check the color shade would be advisable.
Could you possibly also let me know if you have tools like fine sandpaper or small spatulas at home? And how comfortable you are working with paints or varnishes?
I often find the whole repair preservation idea somewhat overrated. When you examine the composition of melamine-coated boards, it becomes clear that small chips don’t cause a significant visual difference, and even repair kits cannot perfectly restore the surface. My view: it’s usually better to replace or cover the entire piece of furniture rather than getting hung up on meticulous repairs. This is especially true for IKEA furniture, where it’s often nearly impossible to repair the smooth surface in a way that is truly “invisible.”
GALEO4 schrieb:
It’s usually better to replace or cover the entire piece of furniture rather than spending too much time on detailed repairs. I can’t fully agree with that! Sometimes it’s definitely worth repairing a small damage instead of throwing everything away. With some patience and the right materials, the result can look great and save valuable money and resources! 😄
