ᐅ IKEA BESTA – How can I lubricate the drawer rollers?
Created on: 20 Jun 2017 08:37
Karllo
Karllo
20 Jun 2017 08:37
I have some IKEA Besta drawers, and I’ve noticed that the rollers are starting to become a bit stiff. The drawers don’t open and close as smoothly anymore, especially in the areas with heavier use. I want to lubricate the rollers to improve their function again.
My specific question is: What is the best way to lubricate the rollers on IKEA Besta drawers without damaging any components or worsening the sliding properties? What type of lubricant is recommended (e.g., oil, silicone, grease)? Do the drawers need to be removed for this? Are there any special considerations for the plastic or metal parts of the rollers?
I look forward to practical tips or experiences so I can handle this properly.
letar
20 Jun 2017 10:52
Hello Karllo,
For re-lubricating the rollers of IKEA BESTA drawers, I recommend the following:
- Removing the drawer makes the process easier and prevents damage.
- The rollers should be treated with a suitable lubricant. The best options are food-grade silicone spray or light machine oil.
- Grease is less recommended because it attracts dirt, which can reduce smooth operation.
- Be careful with plastic parts: never use solvent-based oils or oil-based silicone, as these can damage plastics.
- Before lubricating, clean the rollers with compressed air or a brush to remove dirt and dust.
In summary: remove the drawer, clean the runners, lightly apply silicone spray, then reinstall the drawer. This ensures smooth movement without damage.
silako
20 Jun 2017 13:26
letar schrieb:
- Rollers should be treated with a suitable lubricant. The best option is a food-grade silicone spray or a light machine oil.
I wouldn’t fully agree with that statement.
While silicone spray is often a quick fix, not all silicone sprays are equally suitable for long-lasting lubrication in mechanical parts like rollers. Some dry out or attract dust. Machine oil, on the other hand, can cause issues with plastics depending on its formulation.
Also: Was the problem really caused by friction-related dryness, or could it be due to worn or misaligned rollers or tracks?
My suggestion: First, carefully inspect the condition of the parts, checking for wear and incorrect installation if applicable. Then use a specialized lubricant designed for plastics, usually based on PTFE or Teflon.
In any case, apply sparingly to avoid dripping or attracting dust.
REPITAR
21 Jun 2017 07:14
Hello Karllo,
I would like to address this topic with a step-by-step guide, as I had similar issues and solved them well this way:
1. Completely remove the drawer from the BESTA shelving unit by releasing the locking mechanism on the back of the rollers (usually a small lever or button).
2. Carefully clean all visible dust, lint, and old lubricant residues from the track and rollers using a soft cloth and some warm water. This prevents new lubricant from becoming contaminated.
3. Choose a lubricant containing PTFE (e.g., PTFE spray) or a special plastic-compatible lubricant, as these work very well for the plastic-metal combination of the rollers.
4. Apply the lubricant sparingly to the roller axle and the guide rails. Avoid getting lubricant on the plastic rollers themselves, as they can be slightly porous and absorb the lubricant.
5. Reinsert the drawer, operate it gently, and open and close it several times to distribute the lubricant evenly.
A common mistake is using too much oil or grease, which causes the guides to become stiff and attract dust. Cleaning before lubricating is at least as important as the lubricant itself.
If smooth operation does not improve after lubricating, check the rollers for damage and replace them if necessary.
