ᐅ IKEA BESTA – How can I keep the drawer slides clean and running smoothly?
Created on: 7 Dec 2023 08:37
cristian40C
cristian407 Dec 2023 08:37Hello everyone,
I own several IKEA Besta cabinets and have noticed that the drawer slides on some of them no longer run as smoothly as they did initially. I want to keep my Besta drawer slides clean and operating smoothly without risking damage to the material or mechanics. My questions are:
- Are there specific cleaning products or lubricants suitable for the plastic and metal slides?
- What is the best way to remove dirt or dust from the drawer slides without leaving any residue?
- Should maintenance be performed regularly, and if so, how often?
I am interested in both gentle cleaning and sustainable care to ensure the drawer slides function smoothly for a long time. Thanks in advance for your experiences and tips!
Matthewt487 Dec 2023 09:15Hello cristian40,
First of all, it’s a good approach to maintain the running rails of IKEA BESTA, as they are not difficult to repair but can become problematic if neglected.
For cleaning, I recommend starting by removing coarse dirt like dust or small particles using a vacuum cleaner attachment or a fine brush. Be careful not to press too hard or cause any damage.
For lubrication, I prefer using silicone oil or a special spray lubricant that is non-sticky. I would avoid WD-40 because it attracts dirt and is not ideal for use on plastics.
Important: Do not use oil that is too liquid or grease that becomes sticky. Lubricate sparingly, only once or twice a year depending on frequency of use.
If the running rails are fairly new, thorough cleaning and careful drying often suffice.
If you want more information about maintenance, feel free to ask!
In response to cristian40’s question about how to keep the sliding rails of the IKEA BESTA clean and smooth, I would like to share a few additional tips:
- First, make sure the sliding rails are free of coarse dirt. You can use cotton swabs or a soft cloth lightly dampened with isopropanol to loosen stubborn dirt. It is important to let everything dry thoroughly afterwards.
- For lubrication, I recommend a dry PTFE spray (Teflon), which does not attract dust and works very well on plastic sliders.
- Regular cleaning every 6 months is advisable, especially in dusty environments. You can adjust the frequency depending on how often the cabinets are used.
- If it is possible to remove the rails, a thorough cleaning of all components with a mild soap solution is an option; then dry everything well before lubricating.
This way, the mechanism stays smooth and durable.
First of all, thanks to cristian40 for the clear and detailed question.
For the maintenance of sliding rails, the following is important from a technical perspective:
- Disassemble the rails for heavy contamination to clean individual parts.
- Use lubricants that are specifically approved for plastic/metal connections only.
- Aerosol sprays containing PTFE are often ideal because they leave a dry, non-sticky layer.
A small tip: Vacuuming dust before lubrication is a simple but extremely effective measure.
Regular maintenance depends on usage; under normal household conditions, usually every six months is sufficient.
Those who want to monitor the condition of the rails over time should use the smoothness of operation and the behavior of the drawers as indicators.
Matthewt48 schrieb:I can only confirm that. WD-40 often dissolves adhesive residues and can damage synthetic materials.
I would avoid WD-40 because it attracts dirt and is not ideal for plastics.
In addition to the previously given advice, I would like to systematically summarize what should be considered when maintaining IKEA BESTA sliding rails:
- Cleaning:
- Remove dust and dirt using a soft cloth, vacuum cleaner, or cotton swabs.
- For heavy dirt, a solvent such as isopropanol can be used, but only sparingly.
- Avoid aggressive chemicals that could damage the plastic and coating.
- Lubrication:
- Use only lubricants based on PTFE or silicone.
- Do not use oil-based or greasy lubricants, as they attract dust and cause sticking.
- Apply lubrication sparingly to avoid leaving residues.
- Maintenance:
- Check regularly every 6 to 12 months depending on usage and environmental conditions.
- For heavy use, choose shorter intervals.
- Installation:
- If possible, remove rails for cleaning.
- Ensure all screws are tightened to prevent unnecessary play.
This approach is practical and takes into account material compatibility, operational safety, and durability.
- Cleaning:
- Lubrication:
- Maintenance:
- Installation:
cristian40 schrieb:
I want to keep my BESTA sliding rails as clean and smooth as possible without risking damage to the material or mechanics.Cleaning with a dry cloth will not cause scratches. Dirt can be removed with isopropanol, but use it sparingly. Lubricate with PTFE spray, which is non-sticky and lasts well. Do not use oil or WD-40. Check regularly to ensure everything is still running smoothly.
