Hello everyone, I recently bought an IKEA Besta sideboard and now want to install important child safety locks before our little ones discover the doors. Since the Besta system is quite versatile with its various door and drawer options, I am wondering which type of lock is best suited to childproof the doors without having to deal with complicated mechanisms every time. Does anyone have experience with which child safety locks work best for IKEA Besta, whether there are specific products for this or if universal solutions are better? Any tips on installation or long-term use would also be greatly appreciated.
Basically, with IKEA BESTA you have several options for child safety locks. Many people choose so-called magnetic locks, which are installed inside the doors and can only be opened with a special magnetic key. This is simple but often effective, as the mechanism is not visible from the outside and the appearance is preserved. It is important to check beforehand whether your doors have enough space for internal installation, as some models are a bit narrower. Alternatively, there are also clamp or twist locks that are attached directly on the outside, but these can look somewhat obtrusive or be easier for children to overcome.
I know exactly how challenging this issue is when little ones want to explore everything they shouldn’t. Personally, I initially used magnetic locks with our Besta system and found them very practical because they offer both safety and quick access when opening. I can also understand the concern about whether the security will hold up in the long term or if the children will eventually figure out how to bypass it. Patience pays off when you choose the right products and regularly check the doors.
PULAU schrieb:
Many people use magnetic locks that are installed inside the doors and can only be opened with a special magnetic key. That does sound interesting. Do you happen to know if these magnetic locks are easy to install by yourself? I have some experience assembling furniture but want to avoid damaging the surface. Are there specific tools that are useful, or is it better to get some professional help? The installation should be as straightforward as possible and not leave large holes or visible drill marks.
Regarding the installation of the magnetic child safety lock for IKEA BESTA, I can provide a brief overview:
- First, you should carefully measure the doors and determine the mounting location according to the instructions. Usually, these are small areas on the inside of the cabinet doors and the frame.
- For installation, you typically need a screwdriver, possibly a cordless drill with a small bit, and a suitable drill bit if there are no pre-drilled holes.
- The safety clips are usually fixed with screws; adhesive versions are rarely durable under constant use.
- It is important not to drill holes in visible areas, so placing them on the back of the doors is recommended.
- Tip: Before fully tightening everything with screws, test the function with the magnetic key to avoid problems when opening later.
If you are unsure, local tradespeople or friends with some experience can usually help quickly, saving time and protecting the furniture.
In summary: Installation is quite manageable with basic tools, just pay attention to precision, and it can be done without visible damage.
