ᐅ Ikea BESTA – How Can I Customize Finger Pulls Myself?
Created on: 20 Jan 2024 19:07
Songe
I want to customize my Ikea Besta cabinets to make them a bit more unique and plan to modify the existing recessed handles myself or design new ones entirely. My question is: What is the best way to create custom recessed handles for Besta cabinets without compromising the stability of the doors? I’m looking for ideas and methods ranging from simple changes in color or material to more hands-on approaches such as inserting special inserts or reworking the recesses. It is also important to me how to implement these changes so that they are durable and visually appealing. Naturally, I am also interested in which tools or materials are suitable for this and if there are any potential pitfalls to avoid.
Jeanbar
22 Jan 2024 16:41
Songe schrieb:
Does anyone have experience with using a Dremel and films together?
I applied films after milling in a similar project. It is important that the edges of the recess are very well sanded and dust-free to ensure the film adheres properly. I recommend sanding with fine sandpaper (grit 220 or higher) and wiping down with a clean, lint-free cloth.
Regarding the film: high-quality furniture films are quite durable; they can withstand handling and movement, but they are not indestructible. Usually, the adhesive layer holds for months to years if the surface is well prepared. For paint, I suggest acrylic paints with a matte finish, as they are more durable than spray paints.
Before making major adjustments, I would practice on an old piece of wood or the back side of a door so you can better estimate your approach.
kasan
23 Jan 2024 09:58
Mufato schrieb:
Gluing is usually better than screwing.
I view this point critically and like to question it. While glued joints are clean and can be stable, the durability largely depends on the gluing technique and material combinations. In frequently used furniture—like a Besta handle recess—depending on the stress, the foil or inserts may eventually tear off.
Alternatively, a very fine, well-placed screw in an invisible area can provide long-lasting stability if the screws are fitted with cap nuts or concealed covers. Mechanical connections using small recesses can also help distribute the adhesive load and prevent cracking.
Therefore, I would recommend clearly evaluating the expected load and possibly combining several methods. Especially when modifying the recess design, technical aspects should align with the chosen design. Has anyone had good experience with mechanical-adhesive combination solutions here?
