ᐅ Ikea BESTA – How can I prevent stress cracks during assembly?
Created on: 13 Nov 2015 11:03
V
vinfrederi
V
vinfrederi
13 Nov 2015 11:03
Hello everyone, I am currently planning the assembly of my new Ikea Besta cabinet system and have been focusing on how to prevent stress cracks on the surfaces. My specific question is: How can I avoid stress cracks during the assembly of the Ikea Besta system, which typically occur due to improper joining or overtightening of screws? I have already read some tips covering everything from storage of the parts and preparation to the actual assembly, but I am interested in practical, proven methods—especially regarding the treatment of edges and joints to ensure the surfaces and finishes remain undamaged over time. Looking forward to your experiences and explanations!
Teresa
13 Nov 2015 11:46
The most important thing is not to tighten the screws too much. For BESTA, short turns are enough; full force is not necessary. Also, acclimate the parts for about 24 hours before assembly to ensure the wood moisture is evenly distributed.
RUBEN54
13 Nov 2015 15:29
Hello vinfrederi, very good question, which often comes up with furniture like the BESTA system. Stress cracks usually occur due to uneven moisture absorption or excessive mechanical stress during assembly. My advice:
- Store all panels in the room where you intend to assemble the furniture for at least 48 hours to minimize material stresses.
- Check that the panels lie flat and straight before connecting them.
- Tighten all screws by hand only at first and proceed slowly with a torque wrench or by feel. Avoid over-tightening.
- Use the included dowels and screws in the recommended order to distribute stress more evenly.
- Additionally, you can lightly treat the joints with furniture wax or wax polish to seal small cracks and protect the wood from moisture in the long term.
If you have already discovered stress cracks, I advise against drilling or sanding directly without fine sanding first; it is better to repair carefully.
I hope this helps!
JONKO
14 Nov 2015 10:11
That sums it up very well. When assembling my BESTA, I only started laying out the panels carefully shortly before assembly and underestimated how sensitive the surfaces are.
I also often wonder how carefully one can work during assembly without applying too much pressure on a component – for example, I was concerned that over-tightening the screws could be an issue.
For me, it always helps to work patiently and not forcefully. This is probably no surprise, but after my experience, it really feels like you have to let the material have its way. Maybe others have had similar experiences and can add something?
U
usteto
15 Nov 2015 09:37
vinfrederi schrieb:
How can I prevent stress cracks when assembling the Ikea BESTA system, which typically occur due to improper joining or overtightening of the screws?
The most important point: do not overtighten the screws. Additionally, you can store the parts at room temperature for about 24 to 48 hours before assembly to allow them to adapt to the humidity.
Fluctuations in moisture are the main cause of stress cracks. Use the included fasteners according to the instructions and avoid applying unnecessary force when gluing or pressing parts together.
