ᐅ Ikea Besta/Framsta TV unit combination
Created on: 27 Oct 2009 10:26
gruener.puma
gruener.puma
27 Oct 2009 10:26
I am planning to get the Besta/Framsta TV combination with the glass panels. Unfortunately, the glass panels are safety glass, which means you cannot cut holes for cables in them. Has anyone solved this problem? Is it possible to saw or file down the aluminum rails of the Framsta elements so that the cables can pass through?
Regards,
Sven
Carah
16 Jan 2010 21:31
There is no solution for that yet; it seems they are working on new glass 🙂
O
oliver5378
20 Jan 2010 14:53
Hi!
I’m facing the same issue and came up with a solution: cutting a connecting rail between two panel elements twice and removing the middle piece (about 10–15cm (4–6 inches) wide). This creates a gap between two glass panels where almost any type of cable should fit. The overall structure should still be stable since it’s screwed to the pipe elements on the sides.
However, the cables need to be installed before the final assembly because most connectors probably won’t fit through this gap later on.
I’m planning to try this out by mid-March. I’ll report back to let you know if the theory works in practice.
I’m also curious if Ikea might offer an alternative solution, hopefully before I assemble everything.
Regards
oliver5378
Carah
6 Feb 2010 13:10
So, the new glass panels are finished. They will probably be available for purchase starting April 1st. There is no need to cut or mill an opening anymore, as they are already pre-cut 🙂
