londoneye28 Jun 2010 14:47Hello everyone,
I have purchased a Besta / Framsta combination that looks roughly like this, but with only (4) panels on the left side. On the right side, instead of panels, there are Besta cabinets of the same height. My questions:
1.) Is there an installation guide for the Framsta panels?
2.) At how many and which points should the panel be fixed to the wall? As mentioned, there are 4 panels, consisting of one base unit and 3 add-on units. The TV to be mounted weighs about 25 kg (55 lbs).
3.) Can I assume that using 8 mm (5/16 inch) anchors with 5 x 50 mm (2 inch) screws will provide adequate support on a concrete wall?
Thank you very much for your help,
Christoph
Christoph
Denise_516828 Jun 2010 15:05I have a guide... but basically, it’s simple... you just need to insert the wall mounting brackets into the second-to-last cross brace and then screw them to the wall there... I can also scan it and send it if you want...
I’m not sure if just screwing them in is enough... I’m not very familiar with this kind of stuff as a woman 😀
