ᐅ Ikea Besta DIY: How Do I Build the Front Panel Using Wood Strips?
Created on: 16 Jul 2023 08:23
branimir38
Hello everyone, I am currently planning my next DIY project using the Ikea Besta system and want to enhance the fronts with wooden strips. My question is: How can I construct the front of a Besta cabinet with wooden strips so that the result looks both visually high-quality and modern, but is also stable and durable? I am also interested in how to best attach the wooden strips without damaging the fronts or affecting the functionality of the doors. What materials, processing methods, and tools do you recommend for this? Are there any specific tips regarding measurements, spacing of the strips, or surface treatment of the wood? I would appreciate detailed instructions and practical experience, especially concerning mistakes to avoid. Thanks in advance!
I really like how detailed everyone is in describing their steps here. For someone like me who only does DIY occasionally, tips like these are invaluable!
A few months ago, I covered a Besta front with wooden strips – but I used self-adhesive strips from the hardware store. The result was fairly neat, but after a short time, the edges started to lift here and there, especially when it got warmer in the summer.
Maybe it’s due to the adhesive strength, or possibly the wood expanding. I’m now considering properly attaching the strips with wood glue, even though that’s more work.
From my experience: patience and precision are key; otherwise, you’ll end up frustrated. It’s best to take it step by step, especially when aligning the strips. And always close the doors temporarily from time to time to check the fit.
Hopefully, this perspective helps you a bit, branimir38.
Joe52 schrieb:
A few months ago, I covered a Besta front with wooden strips – but I used self-adhesive strips from the hardware store. That reminds me of my early days! I initially thought it would be quick and easy with ready-to-stick strips, but that wasn’t a sustainable solution.
I then switched to a combination of wood glue and small nails (in concealed spots). First, I glue the strips, clamp them in place, and immediately add small brass pins as additional fixing. After drying, I sand everything cleanly.
Patience is really important here because you need to repeatedly check that the doors can still close smoothly without resistance. One special tip: Be careful when sanding to avoid damaging the front’s finish.
Another helpful trick is to use a slight tongue-and-groove method on the strips, which gives them more hold and a tighter fit on the door.
My conclusion: It’s better to invest a little more time upfront for a truly high-quality front that you can enjoy for a long time.
I just wanted to briefly mention that I do appreciate when a panel with wooden strips conveys a certain natural look—not perfectly straight edges, but rather a handcrafted touch.
I once looked at a panel someone completely built themselves with custom strips on the Besta unit. Especially when choosing the wood type and surface treatment (for example, oiled instead of lacquered), it often creates an interesting contrast to the clean, modern cabinet.
Regarding your project, branimir38: Are your panels still mounted on pivot hinges? If so, you should definitely test before installation to make sure the strips don’t rub against the cabinet carcass, especially with doors that have double strips or 3D decorations.
By the way, I also think that adding wooden strips to a standard Besta panel can give the simple cabinet system a very personal touch without much effort, which adds a lot of value to the living space.
