ᐅ Ikea Besta DIY: How to Create a Custom Front with Wood Slats?
Created on: 13 May 2021 17:42
grant44
grant44
13 May 2021 17:42
Hello everyone, I’m planning to create a custom front for my Ikea Besta shelving unit using wooden strips to give the piece a special, higher-quality appearance. I want to use solid wood strips, carefully and precisely fitting them onto the existing doors.
My detailed questions are: What is the best way to measure the wooden strips without damaging the Besta doors? Which adhesive or fastening method would you recommend to ensure a strong, durable bond that remains reversible? And do you have any tips on how to avoid unevenness or light gaps between the strips and the door, especially when working with different wood thicknesses? Perhaps someone also has experience with surface finishing to make the strips match the cabinet color harmoniously.
Thank you in advance for your advice and tips!
Giagau
13 May 2021 19:11
This topic is really interesting, especially if you want to customize the Ikea Besta fronts. I would recommend first measuring the wooden strips precisely with a caliper and adjusting the width as accurately as possible, ideally to the nearest millimeter. For fastening, liquid wood glue is a good choice because it forms a strong bond while still allowing some flexibility in case adjustments are needed later on. It’s also important to sand the fronts thoroughly and possibly stain them before mounting the strips, so the surfaces harmonize optimally. To avoid gaps caused by misalignment, I suggest temporarily gluing the strips on a flat surface first and then attaching them to the front itself. Using a clamping rail or a tongue-and-groove system might also help if the strips are prepared accordingly.
lorena
14 May 2021 08:27
grant44 schrieb:
How can I best measure the wooden trims without damaging the Besta doors?
Accurate measuring is crucial for a clean result. I recommend a multi-step approach:
- First, trace or measure the visible area of the front onto paper without pressing on the surface. This helps prevent scratches or damage.
- Then, measure the wooden trims precisely for thickness, width, and length – a digital caliper or dial gauge is very helpful here.
- It’s important to include tolerances for expansion caused by varying humidity levels during the planning phase.
grant44 schrieb:
Which adhesive or fastening method is recommended to ensure a durable, stable connection that remains reversible?
For fastening, I usually use a combination of double-sided tape and wood glue. This allows you to fix the trim in place initially and then let the glue cure. Avoiding screws or nails improves reversibility. Small wooden wedges or clamp rails can also help during installation and can be removed afterward.
grant44 schrieb:
Any tips on how to avoid unevenness or gaps of light between the trims and the door, especially with varying wood cross-sections?
Here, I recommend securing the trims on a flat surface before installation and checking them with a steel straightedge. If there are uneven spots, you can smooth them out with fine sandpaper or a router. Careful planning and precise alignment in tight spaces are essential.
One more tip for finishing: you can treat the trims with a hard oil or a suitable varnish matched in color to the Besta front. Test first on an inconspicuous area.
reni45
14 May 2021 10:36
I would cut the moldings precisely, then fix them with mounting adhesive. Important: clean the surface before gluing. To prevent gaps under the moldings, use a soft rubber underlay. For the final treatment, I recommend a matte hard wax oil, which keeps the texture visible. Done.
RON57
15 May 2021 11:14
I would like to add a few points here: When measuring, I emphasize the importance of double-checking the dimensions and holding the trim pieces against the door before installation to verify the fit. Materials like solid wood can expand or contract with changes in temperature and humidity, so it’s important to account for small gaps during planning.
For the adhesive method, a combination of wood glue and transparent mounting tape works well. The glue provides strong adhesion, while the tape stabilizes the pieces during drying. To minimize unevenness, it’s a good idea to align the trim pieces on a flat work surface and check them with a spirit level or a straight edge before mounting. If the wood trim has varying cross-sections, I recommend sanding them beforehand for a uniform surface.
For aesthetics, I suggest treating the trim with a color-matched oil. This keeps the natural grain visible while allowing the finish to blend with the cabinet. If possible, cutting the corners of the trim cleanly with a miter saw greatly improves the overall appearance.
One more note: if you don’t want to make permanent changes to the fronts, you can also use fine hook-and-loop strips for attachment. This is reversible but still holds well under light use.
