ᐅ Ikea Besta DIY: How can small damages be visually concealed?
Created on: 17 Jan 2021 08:12
Nane62
Nane62
17 Jan 2021 08:12
Hello everyone, I have a question regarding my Ikea Besta DIY project: What methods or materials do you use to discreetly conceal small blemishes or scratches on Besta surfaces? Specifically, I’m dealing with minor dents and scuffs on the white fronts and plastic surfaces. I’m not looking for extensive repairs but rather targeted solutions that are durable and easy to apply. Are there any special products that have proven effective? Also, what about practical tips, such as using materials commonly found around the house? I look forward to your experiences and advice!
V
valentino
17 Jan 2021 09:26
For small damages on Ikea Besta furniture, using matching repair markers or wax fillers specifically designed for plastic surfaces is the most effective solution. These products come in various shades of white and can be easily applied to targeted areas. It is important to clean and thoroughly degrease the surface before application. Alternatively, minor scratches can be gently roughened with fine sandpaper and then repaired with a suitable paint or a special plastic lacquer. Home remedies such as toothpaste or vinegar are not recommended, as they rarely provide lasting results and may potentially damage the surface.
Ryder35
17 Jan 2021 10:04
I always use repair wax for small scratches. Simply apply it with a spatula, let it dry, and then polish. It holds well and looks neat.
kulau
17 Jan 2021 11:49
To achieve a clean and durable repair on the white fronts of the Ikea Besta, I recommend the following approach: First, carefully clean the damaged area—I use isopropanol because it dries quickly and leaves no residue. Next, lightly sand the affected area with very fine sandpaper (grit 600 to 800) to help the filler adhere better. For the filling, a wax filler or putty specifically designed for plastics in white is suitable, which can be purchased at hardware stores or online. If applied thinly and carefully, these fillers can be sanded smooth with very fine sandpaper after curing, and then repainted with a matte white plastic paint. It is important to apply the paint in several thin layers and allow each layer to dry thoroughly. This results in an almost invisible transition. An alternative with less effort, but more visible results, is to use repair kits specifically matched to Ikea surfaces. I would like to know how large the damaged areas are in your case and whether the furniture is subjected to heavy use, as frequent contact can reduce the repair’s durability.
Nane62
17 Jan 2021 12:07
kulau schrieb:
I would like to know how large the damaged areas are for you and whether the furniture is subjected to heavy use? Because with frequent contact, the durability of the repair may also be limited.
The damaged areas are usually between 1 and 3 cm (0.4 and 1.2 inches), mostly shallow dents or minor abrasions. Especially the fronts in the living room are used frequently, so there is definitely some wear and tear. My main concern is that the damage is no longer visually distracting and that it does not become noticeable again quickly. Durability is of course also important; I do not want a repair that becomes visible again after a short time.
V
valentino
17 Jan 2021 13:33
Nane62 schrieb:
The damage spots are usually between 1 and 3 cm (0.4 and 1.2 inches), mostly shallow dents or light abrasions.
For this size of damage, a combination of repair wax followed by touch-up painting is ideal, especially in high-traffic areas. White touch-up pens for solariums or furniture, available at hardware stores or specialist shops, work well. Make sure to choose products designed specifically for plastic surfaces. If the fronts are matte white, use matte-finish paint for a more natural look.
Clean the surface thoroughly before repair. For dents, I also recommend gently warming the area with a hairdryer – sometimes this reduces the indentation before treatment.
