ᐅ Cleaning IKEA Besta: How Can I Effectively Remove Grease Stains?
Created on: 19 Aug 2020 14:23
MeomatheusM
Meomatheus19 Aug 2020 14:23Hello everyone, I have an IKEA Besta sideboard with white matte fronts that I regularly clean and dust, but I have recently noticed some grease stains on the doors. Since I want to prevent these stains from becoming permanent or penetrating the material, I am looking for an effective way to remove grease stains without damaging the surface. I have already tried mild cleaning agents like dish soap, but there is always a slight greasy residue left or no visible improvement.
Maybe someone here has experience with specific cleaning products or home remedies that work well on IKEA Besta furniture? It is important to me that the cleaning method is safe for the material (melamine-coated surface) and does not cause any discoloration or dull spots.
I would appreciate practical tips and recommendations.
Hello Meomatheus,
For greasy stains on melamine-coated furniture surfaces like IKEA Besta, it is recommended to first remove them mechanically using a microfiber cloth and lukewarm water with a mild, neutral dishwashing detergent.
- The detergent should be grease-cutting but gentle to avoid damaging the surface.
- Do not make the cloth too wet to prevent liquid from seeping into the edges.
- After cleaning, wipe again with clean water and dry thoroughly.
If the stains are stubborn, diluted alcohol-based cleaners (e.g., 70% isopropanol) can be applied carefully. These effectively dissolve grease residues but may damage the surface if used excessively. Therefore, use sparingly and test on an inconspicuous area first.
In general, abrasive cleaners or aggressive solvents (acetone, paint thinner) are not advised as they can damage the coating.
In summary: start with mild cleaning using dishwashing detergent, if needed use a light alcohol cleaner, allow to dry fully, and avoid treating the surface with furniture polish afterward, as it may leave residues.
Dopoki schrieb:
If the stains are stubborn, alcohol-based cleaners (e.g., 70% isopropanol) diluted and applied carefully can help.That basically makes sense, but do you have specific recommendations regarding the dilution ratio and application time? Often, aggressive use, especially on melamine-coated furniture, not only causes the surface to become dull but can also change the color.
I wonder if a combination of warm water, mild soap, and perhaps a gentle soft soap (which is good at dissolving grease) might be more suitable?
I’m also interested in how grease-cutting household cleaners containing citrus extracts (e.g., orange oil) perform. Are they advisable, or rather problematic, since they sometimes contain solvents that could damage the surface?
What are the practical experiences beyond theoretical advice?
plo60 schrieb:
I’m also interested in how advisable or problematic grease-cutting household cleaners with citrus content (e.g., orange oil) areIn practice, I advise against using cleaners with citrus additives or other strong solvents on melamine-coated furniture.
These products can damage the coating, causing it to become dull over time or develop discoloration.
A proven method, widely used in professional cleaning circles, is:
- Warm water with a few drops of neutral dish soap
- Gently rubbing with a microfiber cloth
- Treating stubborn stains with a cloth lightly dampened with isopropanol (use sparingly and always test first)
Another tip: Remove stains immediately to prevent prolonged exposure and penetration into the layers.
plo60 schrieb:
That sounds generally reasonable, but do you have specific recommendations regarding dilution and application time?Yes, gladly:
- Isopropanol can be diluted 1:1 with water, meaning 50%, if the surface is more sensitive.
- It is enough to lightly dampen the cloth, not make it dripping wet.
- The application should be brief, wiping lightly for a maximum of 10-15 seconds, without soaking the surface.
- Afterwards, immediately wipe again with a wet cloth to remove any residual alcohol and then let it dry.
This approach minimizes risks while still being effective against grease.
Furthermore, I would be cautious with citrus- or orange oil-based cleaners because they may contain terpenes that can damage melamine surfaces.
The best method is to proceed carefully with mild products and minimal moisture.
