I am currently assembling my new Ikea Besta system and have found some parts of the assembly process quite tricky. Especially when attaching the hinges and aligning the modules, things often don’t fit perfectly, which causes some doors not to close properly or to hang slightly. Additionally, the instructions are quite minimal in some areas, leaving certain details unclear.
What “tricks” or tips have you discovered when assembling Besta furniture to solve these issues? Are there recommended tools, techniques for pre-drilling, or specific assembly sequences that helped you achieve a clean and straight installation?
I would appreciate any concrete advice to help ensure the stability and appearance turn out as best as possible. Thanks in advance!
Hello Tayfur,
I completely understand how you feel. In my recent Besta projects, it was also quite frustrating, especially when the doors don’t close properly – it immediately looks sloppy, even though you’re actually putting in a lot of effort.
What helps me now is first checking the paint and edges for unevenness before putting the parts together – sometimes there’s something rubbing that you can fix right away. With the hinges, I found it useful to first screw the screws in loosely, then carefully align everything, and only tighten them completely at the end.
I also take some extra time for precise alignment using a spirit level and a square – it’s a bit of effort, but it really pays off later. I know the feeling of wanting to finish quickly, but then everything ends up looking crooked and wobbly.
Tayfur schrieb:
What “tricks” or tips have you discovered when assembling the Besta furniture to solve such issues?
Hello Tayfur and all others interested,
I have also gathered extensive tips on the Besta assembly, especially because the instructions sometimes seem a bit superficial. I will try to explain the most important points in a structured way:
- Preparation: Sort all parts before assembly and check for possible damage.
- Tools: A cordless drill with adjustable torque control is very helpful to avoid overtightening or leaving screws too loose.
- Hinges and doors: Loose screws on the hinges allow some play to align the doors precisely. Small washers often help if the doors stick.
- Accurate measuring: Use a spirit level and squares to align corners exactly, especially when assembling multiple modules in a row.
- Sequence: First, build the carcass, align everything straight, and attach the back panels only at the end to connect the modules firmly.
I completely agree; this method prevents later misalignment.
A generally good tip: Patience is key when assembling Besta, do not rush. And if doors stick, light filing or a thin piece of felt on the edges can sometimes help prevent noises or scraping.
If you like, I can also send you a checklist to make sure nothing is forgotten during assembly.
Elias schrieb:
I found it useful to screw the hinge screws in loosely at first, then carefully align everything, and only tighten completely at the end.
Hey Tayfur and all Besta adventurers! 😄
That’s true! Especially after hours of screwing everything together and finally wanting to show something, you often think, “Quick, done, whatever!” But no, taking a little time really works wonders with Ikea furniture.
A few more tips from me:
- Before you screw everything together, try dry-fitting the parts first. That way, you can immediately see where things are tight or don’t fit perfectly.
- Use a rubber mat or a towel to protect the back panels during assembly, so they don’t get scratched – it looks better in the end.
- And very important: For adjusting the Besta drawers, I always use those small adjustment screws on the hinge, but gently, don’t force them ;-)
I know Katan might come across as a bit playful now, but hey, building is supposed to be fun! Having a fitting soundtrack on the side helps me, it lifts the mood ^^
Wishing everyone continued success and patience! 🍀
sarlo schrieb:
Patience is key with Besta, don’t rush.
