ᐅ Ikea BESTA Assembly – How Can I Identify Incorrectly Installed Screws?
Created on: 27 May 2021 14:07
GubusanHello everyone, I recently assembled an Ikea Besta cabinet and am wondering how to systematically check if any screws were installed incorrectly during assembly. There are different types of screws and fastening methods (cam locks, dowels, Festool, etc.), and for some of them, I had to turn quite forcefully. What is the best way to verify if a screw might be inserted at an angle, too loose, too tight, or even in the wrong place? Are there visible signs or tests that indicate incorrect assembly? I want to avoid the cabinet becoming unstable or damaged later. Thanks for your tips!
I find this question very important, especially since assembling the BESTA system can be quite challenging. From experience, incorrectly installed screws usually cause an uneven or loose feeling in the components.
If a cam lock screw feels too loose, often only half of the parts are properly connected. However, a screw that is tightened too much can be equally problematic, as the material may start to crack or dent. My approach is always:
- Do not tighten screws to their maximum limit
- Visually check that the cam lock is properly aligned
- Sometimes you can spot the wrong screw length if the screw protrudes too far or is recessed too deeply
Sometimes I have been unsure whether I screwed something incorrectly, but strong wobbling is almost always a clear warning sign. Are there specific areas that seem suspicious to you?
When asked how to identify incorrectly installed screws in the Ikea BESTA cabinet system, there are several clear criteria:
- Cam locks should sit flush and level in their holes, not tilted or hanging
- Screw torque: too loose means play between parts, too tight can damage the material (e.g., tearing of particleboard)
- Misalignments in the positioning of individual panels can indicate incorrect screw placement or depth
- Protruding screw ends or visible gaps usually indicate improper assembly
A systematic check of every connection after assembly can prevent damage and instability. Important: Ikea often specifies exact torque and assembly sequence, which should definitely be followed.
nojaus schrieb:
If an eccentric screw feels too loose, often only half of the components are properly connected.This is an important point. Additionally, I recommend checking each connection for lateral movement after assembly. If components can move against each other, this indicates incorrectly seated screws. I also pay attention to whether screws are fully tightened and not recessed too deeply into the material, as this can affect stability.
FRANCISCOP29 May 2021 10:37hauklo schrieb:
Cam connectors should sit flush and level in their holes, not tilted or hangingBuilding on that: A misalignment between the cabinet front and the side panels is a clear sign of incorrect assembly. It is important to tighten the screws evenly using the recommended tools to avoid stress and warping.
- Use the correct screw types in the specified locations
- Avoid over-tightening, especially on particleboard and MDF panels
- Check the alignment at the top and bottom after assembly
A systematic visual and functional inspection after assembly is the most reliable way to identify improperly installed screws and prevent cabinet damage.
