ᐅ I would appreciate your help with a rough cost estimate.
Created on: 7 May 2020 08:40
AleXSR700
AleXSR700
7 May 2020 08:40
I am aware that the costs for building a house can vary greatly and that there are countless possibilities and variables. However, we are trying to get a rough idea of potential costs when building a house.
Therefore, I would like to ask a few questions that may seem trivial or even pointless to many experienced users here. But through dialogue with you, I am sure new, unexpected aspects and questions will come up.
The situation is as follows:
We are considering purchasing a plot of land. Since land prices are very high, the plot alone will cost around 400,000 to 500,000 euros (approximately 400,000 to 500,000 USD). In addition, there are fees for the notary, possibly a real estate agent, and, of course, interest on the loan in the end.
We are undecided between traditional solid construction (e.g., masonry) and, for example, a prefabricated house, and we wonder whether there are really cost savings or not.
The house cannot have a basement. It should have a ground floor plus one upper floor, and an attic (not necessarily finished, but should be insulated for potential future conversion). The living area should be about 200 square meters (because there is no basement space, some living area must be "sacrificed" for heating room, storage, a small workshop, etc.).
We would do a lot of the interior work ourselves, such as wallpapering, painting, etc., which is no problem.
In principle, we could also tile the bathrooms and lay the floors ourselves, but we would be interested in an approximate labor cost for this work if hired.
May I kindly ask for your general assessment of current prices?
1. Notary fees? Architect fees?
2. What other costs are incurred when purchasing (property transfer tax, land development [flat rate or depending on need?], land registry entry, etc., etc.)? I have already found some information here: https://www.hausbau-forum.de/threads/liste-der-anfallenden-Baunebenkosten-bauseits-teurer.9737/
3. What would a roughly 200 sqm (2,150 sq ft) house cost in both construction methods, assuming a 25 sqm (270 sq ft) balcony on the first floor?
4. What is the approximate cost per square meter of balcony area?
5. Does the number of rooms matter, or is it mostly about the square meters?
6. For parquet flooring (living area) and tiled floors (kitchen and bathrooms), how much would the labor (excluding materials) roughly cost if hired?
7. If only the sanitary installations are done by professionals and no tiling is done, what would a 10 sqm (110 sq ft) and a 15 sqm (160 sq ft) bathroom roughly cost?
8. How much does a "standard" double garage with a wide door (instead of two separate doors) cost approximately?
What other costs might we have forgotten? We have already started researching, but statements on some websites with “starting at” prices are usually too low to attract customers.
Bonus question, since some areas here are prone to flooding: How much extra would need to be budgeted for the above construction project if building with flood adaptation in mind? This is also probably why a basement is not feasible. Or if anyone knows, what would the cost be for a basement that is "flood-protected," if such a thing even exists?
Thank you very much for your help.
AleXSR700
7 May 2020 08:56
Hello again.
I have continued browsing through the forums and found so much additional information that I would like to delete this thread.
However, I am unable to edit or delete it afterwards. Could a moderator please delete this thread?
Thank you.
face267 May 2020 08:58
It looks like you are still at a very early stage. So it's good that you are already working on the cost calculation.
You could just throw out some numbers, but the question is whether that would be helpful. Maybe start with step 1 before anything else.
400,000 to 500,000 for the plot of land is quite a lot. Since construction costs vary a lot depending on the region, please tell us where you want to build. What is the cost per square meter of the plot?
People often assume 2,000 EUR/sqm (2,000 EUR/sqm) for that, but that usually doesn’t fit depending on the desired features and region. The land price would be an indicator.
That’s why I suggest we discuss a rough calculation before going into details.
By the way, if you have read the thread about additional construction costs, you can take most of the information from there. What will be individual depends on your specific case.
Tassimat
7 May 2020 09:02
AleXSR700 schrieb:
Notary fees?
In Bavaria: 1.5% for notary and land registry, 3.5% taxes, 3.5% real estate agent fees, which adds up to around €42,000 (about $45,000) extra on a €500,000 (about $535,000) plot. You really could have looked that up yourself!
AleXSR700 schrieb:
3. Rough cost of a 200 sqm house for both construction types?
€2000 (about $2140) per square meter of living space plus €25,000 (about $26,700) for a double garage and €50,000 (about $53,400) for additional building costs.
Total for 200 sqm (about 2150 sq ft) is at least €475,000 (around $507,000).
AleXSR700 schrieb:
Architect fees?
I think you can estimate about 15% of the construction cost. Does it have to be an architect?
AleXSR700 schrieb:
What other costs have we forgotten?
Many. Landscaping and the kitchen can be quite expensive. Also, painting jobs. That includes more than just wallpapering.
AleXSR700
8 May 2020 23:43
Hello to both of you.
Thank you for your feedback. Yes, we are still at the very beginning, and the plot is not secured yet.
Here, the price per square meter is around 700-1000€ (about 75-110 USD). So yes, quite a chunk.
I wasn’t aware that notaries also charge fixed fees.
The architect is still under consideration. With a prefabricated house, it’s probably less important. For traditional solid construction, we would tend to go for one. But that also depends on what we can still learn here.
That’s why we are currently reading into things more and more deeply.
