ᐅ Hydraulic Balancing of Underfloor Heating Systems
Created on: 28 Jan 2019 19:03
TomTom250
TomTom250
28 Jan 2019 19:03
I have underfloor heating, but one room is not getting warm. After unscrewing the actuators for the individual room control, the situation improved slightly. However, the flow rate is still too low. Can I adjust it somehow on the transparent flow meters? It is a Pipelife underfloor heating manifold. The valves for the actuators are on the return flow and are now fully open. The glass tubes are on the supply side – this is where I would need to make adjustments (since the valves where the actuators were are fully open).
Is this possible? And if so, how? Thanks in advance to everyone who can help!
HilfeHilfe
28 Jan 2019 19:14
Just call a plumber....
TomTom250
28 Jan 2019 19:31
They have already been there; everyone says something different...
KingSong28 Jan 2019 19:47
If every plumber tells you something different, you are probably asking the wrong questions. The answers from a competent plumber would likely be (order may vary):
1. You don't need to adjust anything there.
2. Sure, you can do that—use a radiator key to turn the flow meters.
3. Why do you want to adjust it on the supply side? Better open all the flow meters on the supply side fully and regulate the flow rate on the return side.
4. I’d be happy to do that for you, but it will cost 500€.
HilfeHilfe
28 Jan 2019 20:44
Someone is trying to save money
TomTom250
29 Jan 2019 16:45
I have now spoken with Pipelife after three installers gave me ten different suggestions (my personal favorite: tear everything out again). The flow rate on the supply line can be adjusted using a SW5 bleed key. In colder areas, increase it slightly until the return flow of the problematic room is as warm as the returns of the other circuits. That makes sense and is logical.
