ᐅ How well do BILLY shelves support loads over 30 kg (approximately 66 lbs)?
Created on: 7 Jun 2021 19:13
Luda5Hello everyone,
I am planning to buy several BILLY shelves from IKEA, but I want to load the shelves with weights exceeding 30 kg (66 lbs). My specific question is: How well do BILLY shelves actually hold loads beyond 30 kg (66 lbs) per shelf?
I am particularly interested in whether the shelf remains stable over time when placing heavy books or equipment on it. Does anyone have experience or technical information about how many kilograms a BILLY shelf board can realistically and permanently support without bending or warping?
I would appreciate it if you could share your experiences, tips, or background knowledge regarding the technical load limits of BILLY shelves. Thanks in advance!
Luda5 schrieb:
How well do BILLY shelves actually hold loads exceeding 30 kg (66 lbs) per shelf?Basically, the BILLY shelf is made from particleboard with a melamine-coated surface, which does provide a certain load capacity. However, the official load limit per shelf according to IKEA is usually around 30 kg (66 lbs), distributed over a maximum width of 80 cm (31.5 inches) under normal load conditions.
It should be noted that the load capacity depends greatly on the width and position of the shelves. The wider the shelf, the more it will bend under load. A 40 cm (15.7 inches) wide shelf generally supports more weight than an 80 cm (31.5 inches) shelf because of the shorter span.
Technically, steel or metal reinforcement in the shelves is not provided, so loads exceeding 30 kg (66 lbs) at critical points can cause material fatigue. Proper assembly is also important: the shelves should always be secured to the wall to prevent tipping.
I am curious what type of loads you are planning—do they differ in nature (for example, static heavy books versus equipment with movement)? The dynamics do play a role in long-term stability.
Additionally, it can help to add extra support brackets or install a center support if you intend to store heavy items permanently. Have you considered this?
Hi Luda5 :-)
I’ve been using my BILLY for years now and have mostly just stored my books in the classic way. I’m not interested in any wobbly setups; for me, this unit delivers exactly what it promises.
Some of my shelves have held over 30 kg (66 lbs) of books at times, and so far there’s been no sagging. Still, I make sure to distribute the weight evenly.
If you want to put heavy boxes or equipment on it, I’d recommend using several narrower shelves or reinforcing the boards for extra support.
Tell me what exactly you plan to place on it—that makes it easier to give specific advice 🙂
kulau schrieb:I completely agree with that—the wall mounting really makes a difference! I always thought it was just for tipping protection, but it also makes the whole thing much more stable.
It’s also important to install it correctly: Shelves should always be secured to the wall to prevent tipping.
Additional information:
IKEA specifies the load capacity of BILLY shelves as 30 kg per shelf evenly distributed (66 lbs), provided the unit is correctly assembled and secured to the wall.
Exceeding this load may cause increased sagging of the shelves, as they are not specifically designed for higher weights.
A simple way to increase load capacity is to install additional supports in the middle of the shelves, such as appropriate shelf brackets or center supports. Alternatively, using stronger wooden boards or metal shelving is recommended if heavier items need to be stored permanently.
This perfectly sums it up. It is also advisable to regularly check the stability when storing heavy items and tighten screws and wall fixings as needed.
In conclusion: If you only plan to store heavy items in specific spots, the shelf may hold them without issue for several months. However, for long-term storage of heavy objects, caution is necessary and structural adjustments may be required.
kulau schrieb:
Applying loads beyond 30 kg at critical points can fatigue the material
