ᐅ How well are Ikea Brimnes furniture pieces protected against moisture?
Created on: 17 Mar 2022 08:23
AmerleHello everyone,
I am currently looking into how well the Brimnes furniture series from Ikea is protected against moisture. I want to clarify this for a potential use in a somewhat more humid room, as I have read that some particleboard furniture can swell or get damaged when exposed to moisture.
I am especially interested in details about the effects of short-term and long-term moisture: for example, water splashes, high humidity, or condensation. How is the surface of the Brimnes furniture treated, and how resistant is the particleboard in general? Are there users who have Brimnes furniture in kitchens, bathrooms, or other humid environments and can share their experiences?
I would appreciate well-founded assessments, particularly regarding possible long-term damage or manufacturing details that might improve or worsen moisture protection.
The Brimnes furniture from Ikea is mainly made of coated medium-density fiberboard (MDF) or particleboard, which features a melamine resin coating. This surface provides basic protection against short-term moisture exposure such as splashes or increased humidity.
However, long-term moisture or constant water contact can cause the engineered wood material—like most furniture made from MDF or particleboard—to swell and become damaged. Even if the surface coating is water-repellent, moisture can penetrate the material through edges or damaged areas.
When used in damp rooms such as bathrooms or kitchens, additional precautions should be taken: for example, ensuring adequate ventilation, avoiding constant water exposure, and possibly sealing the edges. Moisture protection for Brimnes is basic only and it is neither waterproof nor suitable for wet areas.
I can only confirm this and would like to add: If you want to use Brimnes furniture in a more humid room, such as a bathroom, I strongly recommend not placing the furniture near direct water sources and ensuring good ventilation.
The surface coating does provide some protection against occasional moisture splashes, but the edges and screw holes are often weak points where moisture can penetrate. Moisture entering the wood-based material causes swelling and structural damage.
It is also possible to seal the edges additionally with waterproof paint or silicone – this can extend the lifespan in damp rooms but is not an official recommendation from Ikea.
I believe you shouldn’t expect Brimnes furniture to withstand long-term use in a bathroom. Of course, the surface offers decent protection against occasional splashes, but the material doesn’t handle consistent moisture very well.
That’s exactly what I want to emphasize. If you like the furniture, it’s better to use it in bedrooms or living rooms and equip the bathroom with specialized moisture-resistant furniture instead. Otherwise, you’ll end up with swollen edges and damage.
In fact, I already noticed this after less than a year in my guest bathroom, even though I was relatively careful.
jaanda schrieb:
However, long-term humidity or constant water exposure causes the wood-based material—like most MDF or particleboard furniture—to swell and become damaged.
I have Brimnes cabinets in my basement, which sometimes gets quite humid, and I can confirm that the furniture is fairly durable against short-term increases in humidity. However, I do have clearly visible, slightly swollen edges after about 2 years.
I think anyone planning to use Brimnes in rather damp environments should be aware that it is not a waterproof material, and damage cannot be completely avoided over time. Good indoor air regulation and avoiding direct contact with water as much as possible are essential.
For furniture in damp areas, it’s better to look for alternatives made from waterproof materials if you want it to last long-term.
