ᐅ How weather-resistant are Ikea PLATSA units for outdoor use?
Created on: 8 Dec 2024 19:23
Wendelin
Wendelin
8 Dec 2024 19:23
I am currently considering using Ikea Platsa furniture on my terrace but have concerns about its weather resistance outdoors. Can anyone with experience share how weatherproof these pieces actually are? I am especially interested in:
- Which materials are used and how they hold up against moisture, UV rays, and temperature fluctuations
- Whether there are specific treatments to make the furniture last longer outside
- If certain components (such as connectors or fronts) are more vulnerable than the main carcass
I prefer not to buy furniture that deteriorates quickly, as I am usually accustomed to more durable materials for outdoor use like metal or specially treated weather-resistant wood. Still, I like the functional customization and design of the PLATSA series.
I look forward to informed feedback, particularly concerning long-term use or tests you may have conducted.
Thank you in advance!
Elijah42
8 Dec 2024 20:37
Ikea PLATSA is primarily designed for indoor use. The furniture is made from coated wood-based panels, which are not suitable for prolonged moisture exposure or strong UV radiation.
For outdoor use, you definitely need a roof or protective cover. Otherwise, the parts will quickly swell or fade.
Waterproofing treatment only helps to a limited extent, as the construction is not watertight.
Palenar
9 Dec 2024 07:54
Hello Wendelin,
to address your question in more detail: PLATSA furniture is generally made from particleboard or MDF with a melamine resin coating. These materials are designed for dry indoor environments. When exposed to moisture, the boards swell and lose their stability. UV radiation also causes the surface to darken or fade over time.
Regarding your question about the connectors: these are often made from plastic or metal, with plastic parts becoming brittle under UV exposure and metal parts prone to rusting without adequate corrosion protection.
A coating or impregnation only provides superficial protection and may reduce limited moisture absorption but does not prevent swelling when exposed to constant wetness. Therefore, the following are important:
- An absolutely protected location, such as a covered terrace or enclosed porch
- Regular inspection of the furniture for surface scratches and timely maintenance
- Consideration of ease of disassembly and maintenance, as repairs after moisture damage can be complex
There are cases where users have placed PLATSA furniture in very sheltered outdoor areas, especially if not continuously exposed to the elements. However, I strongly advise against exposing them to direct rain or high humidity.
If you really want to use the furniture outdoors, I recommend either a waterproof sealant (such as polyurethane varnishes) or choosing similar furniture made from more durable materials.
What type of outdoor area are you planning exactly? How is the roofing or weather exposure designed?
Kinbu
9 Dec 2024 14:11
Palenar schrieb:
A coating or impregnation only protects furniture superficially and can reduce limited moisture absorption, but it does not prevent swelling from constant wetness.
Exactly, and I’d like to add that Ikea PLATSA furniture is flexible and visually appealing, but not designed for direct outdoor use. It might work reasonably well on a balcony with an overhang if you additionally cover the furniture with weatherproof foil and prevent moisture from remaining on the surface.
However, I would not recommend placing PLATSA furniture unprotected on open terraces or lawns. Since they are made from engineered wood, they absorb water, swell, and may develop mold.
If you want, you can generally store them indoors and only bring them outside temporarily during good weather. Just make sure they are completely dry beforehand so no residual moisture penetrates the wood.
To summarize:
- No direct rain or snow exposure
- Good air circulation
- Cover when not in use
If you can follow these guidelines, there should be hardly any problems.
