ᐅ How warm does the boiler room get – does a heating system emit radiant heat?
Created on: 10 Jan 2018 13:03
Pädda
Hello. Today I have a perhaps rather silly question. A gas heating system is planned for our heating room, which is located on the ground floor. Does such a heater emit a lot of heat? How warm do you think it usually is in a heating room with a gas heater?
toxicmolotof
11 Jan 2018 00:06
It depends... I wouldn’t consider it a general rule, and it also depends on whether a controlled residential ventilation system is installed.
We have underfloor heating, a heat pump (not a split system) with an integrated domestic hot water tank, the heating storage tank, and various electronics (NAS, switch, router, cable connection, multiswitch) all located in a fairly small utility room (6m² (65ft²)). In winter, it is always a bit warmer there than in the rest of the house (about 2°C (36°F)).
I also know that in my old apartment, the gas boiler (or rather the exhaust pipe) heated the kitchen, which didn’t have its own heating.
Baumfachmann
11 Jan 2018 00:55
When it gets warm, it means the work was done poorly.
toxicmolotof
11 Jan 2018 02:13
Baumfachmann schrieb:
If it gets warm, then it was done poorly
Nonsense, another generalization like that. I really don’t like it. Maybe it’s simply a case of many heat sources concentrated in a small area.
CapoDecina
11 Jan 2018 11:19
Pädda schrieb:
Hello. Today I have what might be a rather silly question. A gas boiler is planned for our heating room located on the ground floor. Does such a boiler emit a lot of heat? How warm do you think it usually is in a heating room with a gas boiler?
If it gets warm, then something was done wrong
I fully agree with you! I come from the HVAC field, and a gas condensing boiler should not emit heat into the room. If it does, there is something wrong with the condensing boiler!
Good luck
Knallkörper
11 Jan 2018 13:14
It's not just about the gas boiler! In our case, the utility room is usually the warmest of all, because the ground floor manifold for the underfloor heating is located at the back, with 7 heating circuits, meaning 14 supply and return pipes. But that doesn't really matter, as long as you don't plan to store food there.
Baumfachmann
11 Jan 2018 13:58
Everything must be properly insulated, and the work is often carried out poorly here. My experience has shown this, and devices like a router do not heat up a room.
