ᐅ How to Securely Fasten an IKEA Malm Dresser?
Created on: 2 May 2021 07:23
Lissar42
Hello everyone, I bought an IKEA Malm dresser and I want to securely fasten it to the wall to prevent it from tipping over—especially since I have small children at home. The IKEA instructions include a safety kit, but I’m not sure if that’s enough or if there are better ways to mount the dresser more firmly and safely. Has anyone had experience with wall mounting the Malm dresser? Which anchors and screws are suitable, and what is the best way to attach it, particularly on drywall (plasterboard) walls? I would appreciate detailed tips and perhaps a step-by-step guide or advice on important things to keep in mind.
pikin
3 May 2021 09:45
For wall mounting, screws with a Torx drive are advantageous because they are less likely to slip out of the screwdriver, preventing over-tightening. Torx provides better torque transfer.
A Phillips head is sufficient, but when installing in cavity plaster or metal studs, Torx can be more convenient. It is important to choose the screw size to match the anchor and to use screws that are galvanized or corrosion-resistant (e.g., stainless steel) to avoid rust.
Meoru
3 May 2021 10:21
Torx is more durable for assembly work. Phillips screws are more likely to strip, especially with hard materials. So: better to use Torx.
Lissar42
4 May 2021 07:50
Thank you all very much for the detailed and well-founded advice! Earlier, I ordered two hollow wall anchors and matching Torx screws, and I will secure the dresser to the wall at two points near the top. I really like the idea of using expanding foam, and I will give that a try as well. I will report back on whether everything worked out well.
puvin
4 May 2021 09:01
Great! I’m looking forward to your feedback, it will surely be excellent 😊 If you like, just let me know briefly how it went!
