Some time ago, I bought an IKEA KALLAX shelf unit, but I only recently realized that I didn’t install an anti-tip device. Since I have small children in the house, I now want to add one to ensure safety.
My question is: What is the easiest and safest way to retrofit an anti-tip device on the KALLAX shelf? What materials or special fasteners are needed? Is it advisable to simply use universal anti-tip devices from a hardware store, or should I use specific IKEA parts?
I look forward to your experiences and tips on installation, as well as any advice on the best positioning of the safety device to make sure it works effectively. Thanks in advance!
Tielmedi6131 May 2017 12:12Thank you for all the helpful answers so far!
One more question regarding installation: If I want to attach the tilt latch at the top inside, how exactly should I fix it to the shelf? Can I screw directly into the KALLAX back panel, or is it better to screw through the shelf board into the side panel?
Additionally: Do you have any recommendations for suitable anchors and screws if I have a drywall (gypsum board) wall? I’ve read that regular anchors don’t hold well there.
Tielmedi61 schrieb:
Can I screw directly into the KALLAX back panel, or is it better to screw through the shelf into the side panel?The KALLAX back panel is usually thin and made of hardboard; it is not very suitable for securing the unit to the wall. It is better to drill through the side panels or screw into the upper crossbar.
For drywall, special cavity anchors (e.g., metal anchors or toggle anchors) are recommended, as they expand in the cavity and provide a strong hold. It is important that the screws are long enough to ensure the safety strap is securely fastened.
Tielmedi61 schrieb:
Do you have a recommendation for suitable anchors and screws for a drywall?Definitely go for metal hollow wall anchors. They expand inside the cavity and distribute the load. Plastic anchors can easily pull out of drywall.
Also, don’t screw only into the back panel; try to secure into the side panels and, if possible, into the top wooden frame – this provides greater stability.
If you have enough space, using two fasteners can help distribute the load.
