to my surprise, we managed to hit the target exactly with our house planning for KfW 55. Since the repayment subsidies became more attractive from 04/01/16, I also took a look at KfW 40/40+.
Roughly about the house:
Single-family house with approximately 138 sqm (1,485 sq ft), basement for utility rooms, ground floor, and attic. Gable roof with 18°. Monolithic construction with controlled residential ventilation and an air-to-water heat pump.
The KfW 40+ information sheet states:
- A renewable energy-based power generation system
- A stationary battery storage system (electricity storage)
- A ventilation system with heat recovery
- A visualization of power generation and consumption via an appropriate user interface
So, would a photovoltaic system with battery storage possibly be enough to qualify for KfW 40+?
With a 15,000 € grant, that wouldn’t be a significant additional cost.
dsin8788
dsin8788
HilfeHilfe16 Dec 2015 14:49your architect knows that............
Hi,
I think first you need to reduce from 55 to 40 and then install the Plus Package.
That means lowering Q_p and H´_T from 55 to 40 and from 70 to 55, respectively.
Whether this is possible afterwards is uncertain; you really need to consult the builder of your house or your architect. Personally, I believe a) it is not that simple, and b) it will probably cost a considerable amount of money if it is possible.
What you listed seems to be only the scope for the Plus Package.
Thorsten
KfW-Efficiency House 40 Plus 40 55
QP in % QPREF 40 40 55
H’T in % H’TREF 55 55 70
Additional requirement. Plus Package
Thorsten
Bauexperte16 Dec 2015 16:22Hello Thorsten,
Actually, it's sufficient (assuming the single-family house is not being built on the Kahlen ASten) to have the photovoltaic system* with storage as described by the original poster.
Edit: *of adequate size. The required size is calculated by the specialist planner.
Best regards, Bauexperte
T21150 schrieb:No, not really.
I think you first have to reduce from 55 to 40 and then install the Plus Package.
Bauexperte schrieb:
Hello Thorsten,
No, not really.
The photovoltaic system with storage described by the original poster is actually sufficient (as long as the single-family house is not going to be built on the Kahlen ASten).
Regards, BauexperteNot a bad thing. Then I must have looked at the wrong documents.
That would be ideal for the original poster.....
