we are looking for something to make the windows in our walk-in closet opaque, so that we don’t have to keep the blinds down all the time.
What would you recommend to make the windows opaque?
What would be the best solution?
FrankChief19 Jan 2024 09:03Yes, you can see fully through the windows.
The dressing room has two windows: one facing the side, directly opposite the next semi-detached house, and one facing the garden, where theoretically the neighbors across the street could look in, but from a distance.
The question is, can you apply frosted window film yourself effectively?
Does the film get damaged or peel off under strong sunlight? (The window facing the garden is south-facing)
FrankChief schrieb:
Frosted window film – how difficult is it to apply, can you do it yourself somehow?If you’re not too clumsy, yes. Cut the film to size. Clean the window. Spray with soapy water. Peel off the backing film and spray the adhesive side with soapy water as well. Press the film onto the window and squeegee out the water. Let it dry. Done.
FrankChief19 Jan 2024 09:17Is the film also heat-resistant in summer during strong sunlight?
What type of installation should be chosen for the pleated blind?
As already mentioned, the installation is quite straightforward. We had it done ourselves, mainly because the price was very reasonable. It was hardly worth doing it ourselves. The film is heat-resistant; our windows receive full sunlight in summer, and so far (6 years) we have had no issues.
You can also install the film on just part of the window, for example, on the lower 1.20–1.50 m (4–5 feet) or so, depending on how visible the windows are. The advantage of the film compared to direct glazing is that it can be removed again. Pleated blinds (plissees) are an alternative, but you have to close them in advance. It really depends on the exact situation, especially on how much visibility into the windows there is. If full coverage is necessary, pleated blinds offer the benefit of partial transparency, depending on the situation. The frosted film, however, is fixed.
FrankChief schrieb:
What type of installation should be chosen for pleated blinds?A mounting method that does not cause any damage and allows opening and closing from both the top and bottom.Completely forgot, we have pleated blinds that are mounted on top of the frame (with plastic holders) and adjusted using a cord. They can be removed without any trace and are very flexible, so they are definitely a good alternative to frosted glass. The advantage is the higher flexibility, as you can make the windows fully opaque, partially covered, or raise the blind completely.
