Do you use the same tape for the joint that is also stuck to the wall? A screed installer on MyHammer told me that this is not done. Apparently, there are people on MyHammer who know what they’re talking about...
Quote from the email:
Please do not use edge strips as expansion joints (in areas like doors, etc.). Otherwise, the screed cannot be guaranteed to be level from room to room, and as you can see, the joints cannot be made straight.
What should I use instead?
Sharky schrieb:
There must be a standard, it can’t be that everyone just does whatever they want, right?Exactly. That’s why movement joints are planned by the designer.
Rules for this --> DIN 18560
Whether you definitely need a movement joint at that location depends on how the rooms are used. Are there any sound insulation requirements? Are the rooms heated differently? These are all questions you should clarify with your designer.
Sharky schrieb:
But I still haven't received an answer on whether nothing should be installed there or if something else is needed.....No, nothing needs to be installed there because you'll have tiles covering it anyway.
