ᐅ How to Insulate Water Pipes Outdoors / Underground?
Created on: 28 Mar 2024 16:41
Jansepp
Jansepp
28 Mar 2024 16:41
Does anyone have experience with the best way to insulate or protect a water pipe (hot and cold) outdoors? Our new heating system will be installed in an outbuilding. The pipe will be buried only about 1 meter (3 feet) underground.
- So it should be below the frost line.
- But what material should it be embedded in, and how should the pipe be insulated?
- Copper or stainless steel? Which is more advantageous?
Thank you very much!
28 Mar 2024 21:15
I assume the house is not built yet and this concerns new construction planning?
If that’s the case, theoretically the design flaw can still be corrected.
Because based on the content of your question, the system is not installed outside the thermal envelope. But is the outbuilding insulated?
Jansepp
28 Mar 2024 23:25
Hello, no, this is an older building. The outbuilding is currently being insulated. Since a wood gasifier is being connected and the wood is prepared right next to it, this also makes sense, especially because the basement of the existing building is too low to install the connected buffer storage tanks there. Therefore, it is not a perfect solution but the best under the given circumstances.
Harakiri
29 Mar 2024 13:37
If you want to do it yourself easily, use PVC pipes (KG pipes) as mechanical protection and insulate the lines with Armaflex AF or similar insulation materials. The insulation thickness should ideally be 100% (more is better). Then foam-fill any empty spaces.
However, you may need to consider how to make the PVC pipes watertight through floor slabs or walls, possibly against pressurized water.
If you can afford it, use stainless steel, but it only makes sense if your entire installation is made of stainless steel.
Jansepp
29 Mar 2024 14:02
Harakiri schrieb:
If you want to do it simply/by yourself, use KG pipes as mechanical protection and insulate the pipes with Armaflex AF or similar insulation materials. Ideally, insulation thickness should be 100% (more is better). Then foam any empty spaces.
However, you might need to consider how to make the KG pipes watertight against the floor slabs or walls (possibly waterproof to pressure).
If you can afford it, use stainless steel, but it only makes sense if your entire installation is made from stainless steel.
Hello, thank you for your reply. Passing through the basement wall should work well.
Could you please explain why stainless steel only makes sense if the entire installation is made from stainless steel? I planned to use copper for the installation inside the house (which is already installed as copper there).
