ᐅ How to identify faults in a cable within a LAN?
Created on: 25 Nov 2020 06:05
bauherr201615
bauherr201615
25 Nov 2020 06:05
Hello, I have installed 5 Cat7 network cables in the house. They all start at a patch panel and then go to the network outlets.
The problem now is that one of them doesn't work. I have already replaced the outlet once and connected it to a different port on the patch panel. Each time, the tester shows that channel 8 is not working.
How can I identify the cause here?
rick201825 Nov 2020 06:20
Do I understand correctly that you have already swapped the modules at both ends of the cable in question? Or, as it reads, are you using a punch-down tool?
Are you sure the wiring is correct?
If you have empty conduits, replace the cable. Otherwise, test it thoroughly with a good tester. You can then locate the fault by sound. Ultimately, this means the cable will need to be removed for repair.
Installing a new cable is usually easier...
bauherr201615
25 Nov 2020 06:23
rick2018 schrieb:
Do I understand correctly that you have already swapped the modules at both ends of the cable in question? Or, as it seems, you are using a punch-down tool.
If you have conduit, replace the cable. Otherwise, test it with a good tester. You can then use tone tracing to locate the fault. Ultimately, this means the cable has to be removed for repair.
A new cable would be easier...
Can I possibly test something with a multimeter? I would rather avoid replacing the cable.
T_im_Norden
25 Nov 2020 06:28
Surface-mounted cable or with keystone?
rick201825 Nov 2020 06:29
Of course you can do that. Just measure each conductor at the open ends.
If all have continuity, then your problem is not with the cable.
bauherr201615
25 Nov 2020 06:30
Surface-mounted
