ᐅ How to Build a Prefabricated House? What to Consider During Construction and Financing?
Created on: 24 Mar 2025 12:16
MisterHerrbert
My wife and I would like to build a prefabricated house because it is probably one of the most affordable options. We live in Hamburg and would like to build nearby, including in the surrounding area.
First, how can I find the best and fairest provider, and what should I pay attention to regarding construction and financing? How does the land search work? I usually look for plots on eBay Classifieds, but that probably isn’t the right way, is it?
I would appreciate any tips on how to proceed and what I should consider.
We are in our early 30s and currently have a small amount of personal savings of 40,000€ (about 43,000 US dollars). What would you recommend?
MisterHerrbert schrieb:
I am a complete beginner in the field of new construction or real estate in general. That’s nothing to be ashamed of. Everyone starts with something at some point. However, you won’t succeed unless you acquire knowledge on your own or educate yourself. There are things no one can do for you. But a forum can offer support.
What would you recommend to us? First of all, check your finances carefully. Money isn’t just equity; your monthly income and expenses are also important.
Here https://www.hausbau-forum.de/threads/informationen-um-baufinanzierung-finanzierungs-angebot-zu-bewerten.18200/
you can enter your data. While you do that or gather the information, you’ll likely realize whether your situation looks tight or promising. A household budget planner is helpful if you don’t have, say, €8000 (around $8600) coming into your account every month.
Classified ads, excluding eBay, are linked with mobile and property portals, but by the time the data is updated, the real bargains are already sold. Therefore, subscribe directly to search engines. And don’t just look for “house,” but also for “land” or vice versa and/or “condominium.” Don’t limit your search area too narrowly. Often, a location that’s farther away but well connected by bus or train can get you to work faster than a place that’s closer as the crow flies.
How does the land search work?You should expect that searching for land in Hamburg and the surrounding area will likely take several years. Of course, it’s possible to find something by chance right now, but the probability is rather low. The search itself is difficult, time-consuming, and also highly competitive. During this time, you should focus on increasing your equity and regularly check all available sources.
I am a complete beginner when it comes to new construction or real estate in general. My wife and I would like to have a prefabricated house built because it is probably one of the most affordable options. Nothing could prove the first sentence better than the second.
I would appreciate it if someone could give me some tips on how to proceed and what to watch out for. We are in our early 30s and currently have limited equity of 40,000€ (about 44,000 USD). What would you recommend? Early 30s, quite limited equity, and you don’t mention any children. I would recommend starting at the bottom rung of the property ladder. So definitely not aiming for your dream home in a single step. Perhaps consider a young used house (not significantly older than built in 2010), either small or with a granny flat (and even moving into the granny flat yourself). It should be large enough for the first child until school age, and no more. Larger accommodations can come later.
So, building later and curing beginner mistakes early on. Externally (so search the exact phrase including quotation marks), you can find my "Homebuilding Roadmap, also for you: the HOAI phase model!" (and at the same place also "The In-Between House: a Springboard," which I see for you more at a later stage). For a warm-up, try searching the forum with the keywords "plot service" / "11ant short sale" and the 11ant Barthel tips. Entering the financing section here is best done only with the usual ice hockey protective gear.
Frechdachs25 Mar 2025 09:04ypg schrieb:
Don’t limit the surrounding area too narrowly. Often, you can get to work faster by bus or train from a more distant location than from somewhere closer as the crow flies. To find suitable places, I find the tool "travel time map drive time radius" (the top search engine result) quite useful: for example, in your case, enter Hamburg Central Station and be pleasantly surprised by what places lie within a 30, 40, or even 50-minute public transport radius.
You can then evaluate these locations based on your other criteria, probably starting with the price level.
Aloha_Lars25 Mar 2025 10:59MisterHerrbert schrieb:
My wife and I would like to have a prefab house built because it is probably one of the most affordable options. And what exactly makes you think that?
MachsSelbst25 Mar 2025 17:38MisterHerrbert schrieb:
We live in Hamburg and would like to build nearby, preferably in the surrounding area.
(...) This probably also explains the limited equity.
But that also means, if
We live in Hamburg (...) remains the case and also
(...) would like to build nearby, preferably in the surrounding area.
(...) stays the same, then even with 20 years of “tightening the belt” it won’t work out.
It’s generally difficult to save effectively against inflation. For example, if the land price of 500,000 EUR rises by 5% annually, 25,000 EUR simply vanish without any added value in return.
For Hamburg and its surroundings, you simply don’t have the necessary resources in your early 30s.
