ᐅ How is the Ikea 365+ SÄNDA track lighting rail mounted?
Created on: 28 Jun 2009 00:21
Toots
Toots
28 Jun 2009 00:21
Dear friends of refined living,
Now it has happened: for the first time, I am stuck.
I want to hang three pendant lamps above our dining table using the 365 SÄNDA system.
So today, I bought a 140cm (55 inch) rail and a power connector to get familiar with the system. How do I attach the rail to the ceiling?
What I understand so far is that there are three mounting clips, for which I need to drill three holes with anchors using the included cardboard template. Okay, but how do I then screw the mounting hooks to the ceiling?
And is it correct that the rail comes without an installation manual? The connector had one included.
Thoughtful greetings into the night
Toots
chicki
30 Jun 2009 12:02
Hi,
as far as I know, each of the three mounting clips has a hole.
You drill the screws through these.
Then attach the rail:
- "Flip open" the mounting clips (away from the rail direction)
- Hold the rail in between
- Fold the mounting clips back onto the rail
Clear? 😉
Toots
30 Jun 2009 18:26
Hello Chicki,
thank you for your quick reply. I had a feeling it might be like that. But the clamps are really tight.
I didn’t dare to pry them open.
I will test it again over the weekend.
By the way, I live in GK and visit you in Heerlen quite often.
Nice store, and even better once the new building is finished...
Groetjes
Toots
chicki
1 Jul 2009 10:51
Heeeeeey,
no, don’t pry open the bracket!!! 😀 😉
You basically “turn” it opposite to the direction of the rail track. So don’t hammer the screws in 1000% tight. Only tighten them enough so you can still slightly rotate the brackets. I’m not sure how else to explain it...
So, turn the bracket, hold the rail in place, and click the brackets into the rail by turning them.
alex
Yes, Heerlen is great. Unfortunately, I’m currently down after a wisdom tooth surgery and can’t work.
Berni_2054
12 Oct 2009 22:34
Is this track lighting rail compatible with any other type of lamp? And if so, what components are needed to install three pendant lights on it?
chicki
14 Oct 2009 23:42
Yes, it is.. what you need for your pendant lamps is just the track, the power connector, and three of the connectors between the lamp pendants and the track. And one more thing: plenty of patience when assembling...!
Connector/adapter:
White compact electrical socket adapter with black side
