ᐅ How sturdy is the IKEA BRIMNES when used daily?
Created on: 1 Aug 2022 09:47
clemensri
Hello everyone, I am currently considering getting the IKEA Brimnes furniture piece, but I plan to use it daily and quite intensively. My main concern is how stable the furniture really is with everyday use.
Specifically, I am interested in its durability under continuous use, including the strain from frequent opening and closing of the drawers as well as occasional moving.
Does anyone have long-term experience or can share insights about the workmanship and possible weak points? I would prefer not to end up with loose parts or damaged fittings shortly after purchasing.
Thank you very much for your feedback!
bapar
3 Aug 2022 09:11
I’d like to add my thoughts, as the question of Brimnes’ durability under daily use is often underestimated.
The construction uses ABS edges, which provide a certain level of robustness to the MDF panels. At the same time, the fittings are usually made of galvanized steel, offering some corrosion resistance.
For daily use, I would recommend:
- Not overloading the furniture beyond the specified weight limits, as this can cause the slides and connectors to wear out more quickly.
- Paying particular attention to distributing the load evenly, especially in drawers.
- Assembling the furniture on as level a surface as possible to avoid stress on the joints.
Palenar schrieb:
The BRIMNES system mainly uses medium-density fiberboard (MDF) with a durable coating, which essentially provides a solid foundation.
That’s a very accurate description. The difference to solid wood becomes noticeable in terms of longevity under peak loads.
Are you planning to use the BRIMNES as a bed or for storage, clemensri? Because beds are subjected to additional dynamic forces that should not be underestimated.
clemensri
4 Aug 2022 07:53
Thank you very much for the detailed and helpful responses so far.
To clarify: I am considering the dresser from the BRIMNES series, which I use daily for storing clothes and various items, frequently opening and closing it. Occasionally, it is also moved slightly, but not often.
The advice regarding moisture and regular checking of the screws is very valuable—I hadn’t fully considered that.
Palenar schrieb:
I recommend regular maintenance: checking screws, tightening if necessary, and lubricating the drawer slides with a suitable lubricant as needed.
Could you or someone else please explain in more detail how to best tighten the individual fittings without causing any damage? Are there any particularly sensitive areas on this model that should be watched closely?
Thanks in advance!
