ᐅ How durable are IKEA PLATSA furniture units after multiple moves?
Created on: 4 Aug 2024 09:17
alineHello everyone,
I am currently looking into the stability of IKEA Platsa furniture, especially in the context of multiple moves. Since this furniture series is often rebuilt and reassembled due to its modular design, I specifically wonder: How durable are Platsa units after several assembly and disassembly processes? Are there any experiences regarding how the construction, which usually consists of metal frames and shelves, holds up over time and through moves?
I am particularly interested in whether the connecting elements (dowels, screws, metal fittings) lose stability from frequent dismantling and reassembling. It would also be helpful to know if there are any assembly tips to increase durability or if wear and tear from moving is generally unavoidable.
Thanks in advance for your insights and experiences!
Hey aline, your question is really spot on and hits exactly my point. 😄 I have already completely taken apart and reassembled my PLATSA twice during a move. Of course, after each time, it doesn’t feel as tight as before, but it’s still stable enough not to wobble or bend.
My advice: Make sure to fully tighten the screws every time you assemble, and avoid just partially screwing them in too often. This way, the furniture stays in good shape, almost like new – and it’s also fun because you can easily adjust the parts! 😊
Regarding the stability of IKEA PLATSA furniture after multiple assemblies, the following technical points apply:
- The connections are based on metal frames and quick-fastening fittings designed for repeated assembly and disassembly.
- However, frequent dismantling can lead to material fatigue in screw threads and plastic components.
- The load capacity of individual modules generally remains intact, provided that wear parts are replaced in time or securely tightened.
- For frequent assembly, using thread-locking compounds is recommended to minimize loosening of the connections.
In summary, PLATSA furniture is durable but gradually loses some stability with increased use. Therefore, checking the connections before each use is advisable.
Wow, what an exciting topic! I love my PLATSA furniture; I’ve taken it apart and reassembled it three times during moves and can honestly say it’s very durable! 😊
Sure, some screws aren’t quite as tight as the first time, but that’s simply because the furniture has been moved several times. After a bit of readjusting, everything was stable again. If you take your time during assembly, the furniture is almost indestructible. So go for it and have fun!
dijan schrieb:
Sure, after each time it doesn’t feel as tight anymore, but it’s still stable enough not to wobble or buckle.This observation exactly matches the typical material behavior. Metal frames remain load-bearing, while the weak points are the fasteners—such as screws and plastic connectors—that lose strength under increasing stress. Therefore, it is important to check and replace any worn parts during each move if necessary.
Davidleo schrieb:
After a little adjustment, everything was stable again.This confirms practical experience: regularly tightening the screws can improve the condition. Also, using thread-locking compounds should not be underestimated to prevent screws from loosening again.
